Old 04-27-2013, 02:05 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Is my engine/tranny straight?
How can I be certain that my engine/transmission is straight? Should the tailshaft of the transmission be dead center between the frame? I am using a POL crossmember and my tailshaft is about half an inch off center. This could be what is preventing my headers from fitting. Recommendations please!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-27-2013, 02:20 PM   #2
donut
donut's Avatar
Re: Is my engine/tranny straight?
Can you move the tailshaft over?
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 04-27-2013, 02:40 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
I can but it isn't easy!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-27-2013, 03:33 PM   #4
eray92
eray92's Avatar
is it lined up with your rear end yoke?
eray92 is offline   Reply With Quote
Old 04-28-2013, 02:13 AM   #5
Truck Guy99
If it lines up with your rear axle yoke, you got it straight. I wouldn't worry about damage if it is only a n inch. If you have aftermarket headers, compare them to your old ones. Are they thicker? Wider? Shorter? Need more info here.
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 04-28-2013, 02:39 AM   #6
69GMC910
MOTORHEAD!
69GMC910's Avatar
Did a small to big block swap. Changed complete drivetrain, including crossmember. I don't have a driveshaft yes as I have not completed lowering the truck. Eyeballing it from the dif though it doesn't look too bad.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-28-2013, 10:22 AM   #7
geezer#99
geezer#99's Avatar
A lot of vehicles have the motor/tranny offset an inch to the pass side. Due to steering clearance and rearend pinion offset. If your rear has equal length axles the pinion will be offset. Measure them all. Centre of crank at front, tailshaft and pinion.
When you set up a drivetrain you don't need everything to be in a straight line. Your u-joints won't work like that.
Old 04-29-2013, 09:54 AM   #8
wraprail
wraprail's Avatar
Um... U-joints won't work like what?
Not sure what that means but it is very important that your drivetrain is in a straight line unless you don't care it it vibrates and makes noise.
You can't just throw it together.
Use a tape measure.
If the OP is just replacing a small with a big block ( or other way around) then the motor/trans mounts and crossmember should be same. (Unless switching to a turbo 400/4L80
[size=1]Posted via Mobile Device[/
wraprail is offline   Reply With Quote
Old 04-29-2013, 10:55 AM   #9
69GMC910
MOTORHEAD!
69GMC910's Avatar
I did switch to a turbo 400 from a 350. I went with an aftermarket tranny crossmember.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-29-2013, 01:44 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No, Geezer is dead right. There has to be some angle to the u joint for them to last. The rollers inside of them have to roll a bit during use. If you had a dead straight line from trans output shaft to pinion shaft, you'd be changing u joints regularly due to this.
Many cars over the years have had significantly offset engines and trans for clearance. The driveshaft going a bit sideways when viewed from above is perfectly fine.
The angles of the transmission and pinion in relation to each other should be the main consideration. That's the pinion angle that is so important to reduce vibrations.
Old 04-29-2013, 02:42 PM   #11
Rubble
X2 on the u joints needing some angle.I dealt with this when I worked at an IH farm equipment dealership in mid 80s.The large PTO combines always had a bit of angle on them.Also look at any highway tractor,most of their u joints have some angle too.I have ran lifted 4x4s for years and always had some angle on the u joints too,very little trouble with them too.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 04-29-2013, 07:12 PM   #12
wraprail
wraprail's Avatar
I agree with both posts above.
The pinion/transmission angle which combined = driveshaft angle are the most important and must be correct.
The sideways angle ( horizontal) is a concern for me.
On my own truck I have a ford 9inch which has an offset pinion. I set my driveline angles correctly but there is that sideways angle of the driveshaft. In 6th gear about 80mph and on up to 95 i have a vibration.
So my question ( and this goes to the OP origonal post) is how do you set driveline angle in the horizontal?
Also, my linclon 9inch came factory with a cv joint at the pinion. Now has a standard single ujoint
Old 04-29-2013, 07:49 PM   #13
geezer#99
geezer#99's Avatar
Thanx Tx. I couldn't remember how to explain it or what the damage is called. Maybe galling or brinelling. Just knew you needed some working angle to make the u-joints work right.
Wraprail, I followed a discussion once on pinion angles and pinion offsets and how best to make it all vibration free and found this link. Lots of excellent info in here.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
