Old 04-28-2013, 04:54 PM   #1
mgold97
Carb spacer
Will I still be able to use my stock throttle /kick down bracket if I install 1 inch carb spacer or will I have to go with aftermarket throttle bracket.
Thank you
mgold97 is offline   Reply With Quote
Old 04-28-2013, 08:37 PM   #2
76stepsidechevy
Re: Carb spacer
as far as I know all the stock bracketry works with the spacer. I dont have a kickdown cable but my throttle bracket worked when I had a spacer. As long as the cables are long enough you should be fine, the geometry isn't really changed if the brackets sit on top of the carb mounting holes.
76stepsidechevy is offline   Reply With Quote
Old 04-28-2013, 11:04 PM   #3
mgold97
Re: Carb spacer
ok. Did you have to use(remove/reinstall) one of the intake bolts to mount it. Will effect intake gasket?
Old 04-29-2013, 04:42 PM   #4
tucsonjwt
Re: Carb spacer
It will likely work, but if you have a stock air cleaner with the metal tube running down from the thermo switch on the intake down to the exhaust, then you will be 1" short, and have to rig up something to make the connection. That is why I don't have a spacer on my carb - had it on my 73 454 and was a real PITA.
tucsonjwt is offline   Reply With Quote
Old 04-29-2013, 06:38 PM   #5
mgold97
Re: Carb spacer
I have edelbrock intake, carb and air cleaner with mr gasket 1" carb spacer.
Old 04-29-2013, 11:42 PM   #6
Space Monkey
Re: Carb spacer
I have a spacer and I had to get an aftermarket bracket for mine. The stock one "worked" but the angle of the cable made my accelerator jump from nothing to everything. The bracket wasn't expensive though.
1982 GMC C1500 4x4 w/ 305 and sm465.
2002 Kawasaki Ninja 250.
2007 Dodge Nitro.
Space Monkey is offline   Reply With Quote
