Old 04-29-2013, 08:46 PM   #1
87r10owner
Mcgaughy Drop springs............
I originally put 2.5" drop spindles and 2" springs on my truck (all mcgaughy parts) and it came out too low in the front so I ordered 1" springs thinking I could bring the front up an inch and align it to take up a little more so my truck would sit level but to my surprise after pulling the 2" ones out, the 1" springs only end up being 1/2" taller. Kind of disappointing!!!! Yes the 2" ones are actually 2 1/4" shorter than my factory springs. I really didn't want to cut my springs and wanted my front end to be new. It's just frustrating to spend all that money and it not be what you wanted.
87r10owner is offline   Reply With Quote
Old 04-29-2013, 08:51 PM   #2
baclay9
Re: Mcgaughy Drop springs............
I would go ahead and install them and see how they come out. I bet your ride height will come out where you want. The spring doesn't have to be 1" higher to equal 1" of ride height.
baclay9 is offline   Reply With Quote
Old 04-29-2013, 08:59 PM   #3
87r10owner
I know it depends on spring rate, it just seems odd to me. At this point that's all I can do
Old 04-29-2013, 09:53 PM   #4
Matt8027
I had the same problem with these springs, I installed the 4.5/6 mcgaughys drop and my front end sits way too low
Matt8027 is offline   Reply With Quote
Old 04-29-2013, 10:56 PM   #5
LEEVON
LEEVON's Avatar
Cut the stockers 1 coil on the bottom and with the spindles you will get 4.5" and the ride will be perfect. I PROMISE! Cut them with a cut-off wheel on the grinder, takes like 2 seconds and is free.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-29-2013, 11:03 PM   #6
mgchevyparts
mgchevyparts's Avatar
Most low cost aftermarket coil springs are a crapshoot.
mgchevyparts is offline   Reply With Quote
Old 04-29-2013, 11:10 PM   #7
87r10owner
In still tossing that around leevon!
What would a high cost aftermarket spring be????
Old 04-29-2013, 11:16 PM   #8
naphtali5725
naphtali5725's Avatar
did you try the stock springs after you installed the drop spindles? I wonder if that will be low enough for you, it's free to try it out.
i'm going to do the 2.5 Mcgaughy's drop spindles but using the stock springs. i am not going cut them, or heat them or anything, gonna run them as they came.
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 04-29-2013, 11:19 PM   #9
87r10owner
Nope the only ones I've had in after the drop are the 2" springs
Old 04-29-2013, 11:25 PM   #10
naphtali5725
try the stock ones man, wouldn't hurt to try it.
how was the ride quality with the aftermarket springs?
My build thread...
Disabled Veteran
Old 04-29-2013, 11:31 PM   #11
LEEVON
LEEVON's Avatar
2.5 McG spindles, and one cut coil for height reference. Front fenders went from 33" to 28.5" with 255/70/15 tires. I'm actually going to cut another 1/2 coil. Plenty of room and the ride is great.
Old 04-29-2013, 11:36 PM   #12
naphtali5725
how much total inches will that be, that you have cut off the coils?
what inches is your rear lower? flip kit or hangers/shackles?
My build thread...
Disabled Veteran
