Old 06-02-2021, 02:54 PM   #201
big_dan
Re: 53 3100 - complete rebuild and upgrade . . . .
Originally Posted by bennylava View Post
Question - Was fully boxing the frame necessary? I understand the benefits in terms of rigidity, but would the truck be fine without it? Say you just added a couple new supports. Maybe some beefier cross members. Would that be enough? What are some other reasons to fully box the frame?
Stock frames are pretty much a limp noodle, but i wanted the rigidity and cleaner look to be honest. I'm sure a few added cross members would help though.
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . .
My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean.
https://www.67-72chevytrucks.com/vbo...d.php?t=791886
My 65 Ford project . .
https://www.67-72chevytrucks.com/vbo...d.php?t=792428
big_dan is offline   Reply With Quote
Old 06-03-2021, 05:21 PM   #202
big_dan
A little more progress the last few afternoons getting the body back on for good back space measurements. More later-
Dan
Old 06-04-2021, 09:20 PM   #203
big_dan
So at this point it's looking like all the tape measure work paid off. Front and rear track width is 58"; plenty of room. I'll be able to run a 10" wheel/ tire combo up front and a 12" in the rear with no worries.
I've looked high and low for a decent set of steel running boards with no luck, so I ordered a set today. We'll be able to tinker around with those by next week hopefully.
More later - thanks for looking -
Dan
Old 06-04-2021, 10:17 PM   #204
mongocanfly
mongocanfly's Avatar
Mock up looks great Dan
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-05-2021, 04:23 PM   #205
big_dan
Thanks, mongo.
Here's one of how I hung the exhaust while I'm waiting on running boards -
Dan
Old 06-06-2021, 11:01 AM   #206
big_dan
Rainy day here so figured I'd check another to-do off the list.
Moving the engine back and down brought the sump fairly low (or at least not protected by the crossmember) so I've been plotting on "insurance" for a little speed bump protection. What I decided on was more tube, 1-3/4 × .120 wall as usual. The bottom of the oil pan will be about 6-1/8" off the ground, so I bent/ fitted the tube to bottom out at just under 5" off the ground, which keeps the "oil pan roll bar" just above the running board brackets. I pointed it forward to the high part of the pan so if it did hit hard and bend it's 2" off the pan there. Overall it provides about 1-1/8" of protection without being cumbersome, and bent like it is it won't interfere with oil changes at all. I'll weld it out and gusset it at the frame when the chassis comes off the jig.
More later - thanks for looking-
Dan
Old 06-07-2021, 07:21 AM   #207
6DoF
6DoF's Avatar
the speed bump plow! there is something elegant about the function and form of that tube.
6DoF is offline   Reply With Quote
Old 06-07-2021, 07:26 AM   #208
youngrodder
youngrodder's Avatar
Great forward thinking and protection. I like the shape of the solution as well.. Another well thought out solution my friend.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-07-2021, 05:22 PM   #209
big_dan
Wow - thanks for the compliments, fellas.
I'm just trying to put a little thought into every step. No rush, and I'm enjoying it way more than past builds. I picked up firewall steel today and the running boards are here, so possibly a little more progress this week.
I did start making some room for the big 20's out back this weekend also -
More later. Thanks for looking!
Dan
Old 06-09-2021, 07:39 PM   #210
big_dan
Firewall. I want a smooth one, of course, but nice and rigid for the booster, etc, so I'm using 1/8". The trans/ engine bump in the cab will be sheet metal though. Traced out my first piece, then dug a 2" aluminum round out of the machine tool bin for column mock up, then started playing with the plasma. I'm leaving the outside of the cab where the hood hinge bolts and just smoothing from the "window" shape down. Still have to make room for the intake; this is just initial fit up.
Dan
Old 06-10-2021, 09:32 AM   #211
Rickysnickers
I'm curious, and I like to gt different opinions. How are you going to attach the smooth panel to the existing firewall?
Old 06-10-2021, 12:01 PM   #212
big_dan
The existing panel is doubled up at the top and sides. I'll weld to the existing sheet metal and brace inside. Hope that clarifies it-
Dan
Old 06-13-2021, 08:52 PM   #213
big_dan
Spent a little time on the firewall this weekend. Of course, all of these old projects have secrets it seems. Found some poor rust repair in the toe board area, so I'm having to cut back a little further than I thought to find good metal. But, it'll be done soon enough.
Dan
Old 06-13-2021, 10:24 PM   #214
joedoh
joedoh's Avatar
thanks for catching us up! nice work as usual
forget secrets mine scream. but I dont start with the best donors anyway.
Old 06-15-2021, 08:09 PM   #215
big_dan
Thanks, joedoh. A few more little pics to throw out -
After fully removing the toe board started making the patch. I'm using steel plate (~1/8") for the toe boards and fire wall for the rigidity; I'll use 16 ga for the tunnel and other plans.
Wheels (front) showed up. I decided on smoothie steel wheels; I think they match the look of the 50's trucks best IMO. 18x8 front with 4-1/2" BS. Rear will be 20x11 with 6" BS, but still waiting on them. I grabbed the US Wheel smoothies (bare, I'll have them powder coated) and was super stoked to discover they actually come with the center caps. Of course, I had to slap them on, but can't tell much without the fenders.
More later, thanks for looking -
Dan
Old 06-16-2021, 07:53 AM   #216
youngrodder
Looking good Dan...
Marc
Old 06-21-2021, 06:05 AM   #217
big_dan
Originally Posted by youngrodder View Post
Looking good Dan...
Marc
Thanks, Marc. Weekend distractions aside, we're moving along. Kiddo got in the way a little rebuilding brakes on his 2500. Love to see them doing their own work!
Dan
Old 06-21-2021, 07:23 AM   #218
youngrodder
Dan
Looks like you taught him right...all the way down to throwing down some cardboard so he doesn't stain up his dads concrete....
Happy Fathers Day!
Marc
Old 06-21-2021, 08:47 AM   #219
57FleetsideC4
Everything is coming along great! I use carboard a lot when working on my cars/trucks. It really helps keep the floors nice and a buffer if you have to lay down. Your welding is amazing. Keep up the good work. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 07-09-2021, 06:52 PM   #220
big_dan
So, as it always seems to go, make a little progress here and there and try to dodge side projects.
Unless. ...... They're really cool. Here's the latest side project has been distracting me a little - 1974 Clausing-Colchester 15x50. Excellent shape, just a little dirty. Should clean up beautifully.
More later -
Dan
Old 07-09-2021, 07:22 PM   #221
mongocanfly
me and my tiny lathe are jealous..!!!!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-10-2021, 09:07 AM   #222
8man
Wow! Nice project, and what Mongo said!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 07-10-2021, 05:16 PM   #223
big_dan
Don't be jealous, fellas! I was really fortunate (or lucky) to grab it up; one of those right place - right time deals for sure. I'll have to set up a phase converter, get tooled up with some larger tooling, etc. but I'm looking forward to it. Definitely adds to shop capabilities though!
More later- thanks for looking -
Dan
Old 07-10-2021, 10:05 PM   #224
mongocanfly
i really like those clausing lathes....spent many a day standing in front of one
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-11-2021, 05:05 PM   #225
olcarguy
Puts my little 1952 South bend 9"x36 to shame
olcarguy is offline   Reply With Quote
