06-12-2011, 12:28 PM | #1 |
2002 jimmy s serries
cant find fuse or circut breakers for power seats
06-12-2011, 07:11 PM | #2 |
Old member
Re: 2002 jimmy s serries
Drivers side of dash in the drivers door jam. Pull the little cover off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
06-12-2011, 07:34 PM | #3 |
06-13-2011, 12:41 AM | #4 |
Old member
Google searched.
Left side of the dash, to the right of the IP fuse block. Its a 25 amp circuit breaker, an aluminum cased breaker. CHECK FOR POWER ON THE SEAT SWITCH "A" TERMINAL AND GROUND ON THE "D" TERMINAL. IF YOU HAVE POWER AND GROUND THE SWITCH IS BAD.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 06-13-2011 at 12:45 AM. |
