06-08-2010, 07:33 PM | #1 |
Z-ing a frame (REAR)
Can you z the rear of the frame? What I am thinking is right behind the cab before the bed mounts. Then right in front of the rear bed mounts. I can draw up a sketch but just wondering if it can be done and any ideas on how.
Steel plate and gussets is what I was thinking. Sketch coming tomorrow. Alternatively, if I have to step notch instead, what do I do with my crossmember?
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
06-08-2010, 07:52 PM | #2 |
Re: Z-ing a frame (REAR)
Yes, it can be done..... http://67-72chevytrucks.com/vboard/s...d.php?t=381425
06-08-2010, 09:36 PM | #3 |
You sir are a bas ass! That is exactly what I was going for.
06-08-2010, 10:11 PM | #4 | |
06-08-2010, 11:45 PM | #5 | |
Tags |
notch, z-ing |
