Old 01-12-2006, 05:55 PM   #1
65GMC
Drum to disk
Got a 65 GMC 1/2 ton that I'm working on and was wondering what parts from what make and model vehicle do I need to convert the front drum brakes to disk brakes.
65GMC is offline   Reply With Quote
Old 01-12-2006, 08:09 PM   #2
JRB
JRB's Avatar
Re: Drum to disk
65GMC,
Have you looked at the FAQ Submissions link? If you go back to the menu of different places to look click on that and you will find a section called (FAQ Index Thread) that has tips on how to do things like Drum to Dics Brake conversions.
Hope this helps.
JRB
JRB is offline   Reply With Quote
Old 01-12-2006, 08:11 PM   #3
qksilver
Re: Drum to disk
pretty much pull the whole disc brake front end off from a 70-on up 1/2 truck and the crossmembers bolt in also with drill a couple of holes.
qksilver is offline   Reply With Quote
Old 01-16-2006, 07:10 PM   #4
65GMC
Re: Drum to disk
Thanks for the info.
Old 01-17-2006, 09:42 AM   #5
cajunbowtie
Re: Drum to disk
If you use a after 1971 you will go to 5 lug. I used a 1973. Worked great on my 1965.
cajunbowtie is offline   Reply With Quote
