Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-01-2021, 11:49 PM   #1
Nima
Blue 67
Relays amperage rating
Hello:
I am trying to make my own custom fuse/relay box from a fuse box that I got from junkyard but I am having hard time to find the amperage rating for the relays that were inside the box. When I google the part numbers the specs doesn't show anything about the amperage rating. I was wondering if there is any specific area that anybody knows I can find the info. I am looking for Omron relays # 7234 (12177234), 7236 (12177236)and 8567 (12088567)
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 11-02-2021, 12:47 AM   #2
Accelo
Accelo's Avatar
Re: Relays amperage rating
12088567 Maximum Switching Current 20.0 amps
12177234 Maximum Switching Current 40.0 amps
12177236 same as Part #13503102 Amperage (A): 35 Amp
Accelo is offline   Reply With Quote
Old 11-02-2021, 01:54 PM   #3
Nima
Blue 67
Thank you Accelo. Where do you get this info since I couldn't find anything. I am going to use Ford Taurus two speed fan for my project and I believe at high speed they can have initial draw of 60-70 amps. Do you know of Omron relays (the same size and shape to fit in the same electrical box) with higher amperage rating?
Thanks again
Old 11-02-2021, 04:18 PM   #4
Wrenchbender Ret
The high amp breakers have a wider blade.
George
Wrenchbender Ret is offline   Reply With Quote
