Old 11-18-2021, 01:34 AM   #1
straight6chevyguy
straight6chevyguy's Avatar
Question Oil pump gasket question
So I'm rebuilding a 250 inline 6 for my 1976 C10.
The oil pump gasket that came with my gasket set is not lining up to my liking (hard to explain without showing a picture) I was thinking I would rather make my own gasket but got to wondering if it matters what type of material I use to make it.
Will regular gasket paper work? If so what thickness should I use?
I'm only thinking about this because of the oil pressure. Is this even a problem?
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1998 chevy c1500 4.3L 5speed (My current driver)
2002 Chevy s10 4.3L auto 4x4
1971 mercury monterey wagon 400 auto
To many projects!
straight6chevyguy is offline   Reply With Quote
Old 11-18-2021, 07:25 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Oil pump gasket question
So long as the suction port and pressure port on the pump is covered by the gasket, it will be fine.
I have seen many different variations of port location etc....none of them seem to make a difference so long as the ports are fully surrounded....
Place the gasket on the pump and taje a pic and upload it...that way we can see what your concerns are...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 11-18-2021, 11:16 PM   #3
straight6chevyguy
Edit: I guess I'm stupid I forgot to attach the pic to the post.
Ok here's the pic.
Notice the gap on the upper right.
And yes I have tried flipping the gasket opposite ways and it still has a gap.
To many projects!
Old 11-19-2021, 06:20 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
That is the wrong gasket....that will suck air and not prime...
Post a pic of the gasket sitting on the oil pump face .....
2012 Chevy Equinox
Old 11-21-2021, 10:24 PM   #5
straight6chevyguy
Some more pics.
Gasket on pump.
Gasket flipped around on pump.
Pump without gasket.
Engine block without gasket.
To many projects!
Old 11-21-2021, 10:29 PM   #6
straight6chevyguy
By the way I just realized I was wrong when I said that my gasket came with my gasket set .
It actually came my pump.
My gasket set didn't come with an oil pump gasket for some reason.
To many projects!
Old 11-30-2021, 12:40 AM   #7
straight6chevyguy
So back to my original question: what material should I use to make my own gasket?
To many projects!
Old 11-30-2021, 07:11 PM   #8
AussieinNC
Moderator
AussieinNC's Avatar
Simple...
Take the new gasket that appears to have an incorrect cutout and use a digital caliper to measure the thickness.
Should be around 0.6 to 0.8 mm.
Most auto parts outlets sell various thicknesses of gasket paper.
Do not use cork !!!!!!
2012 Chevy Equinox
Old 01-08-2022, 01:29 PM   #9
straight6chevyguy
Made my own gasket. Thanks guys.
To many projects!
