03-06-2009, 04:46 PM | #26 |
Wide n'Low
Re: Air Ride Tech- One And Only-Limited Time Sale!!!
Just got a Big 4way for Project 50th!..
Thanks Jon, Brett, and company Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
03-06-2009, 04:49 PM | #27 |
Jon@AirRideTech
Awesome! Any time man...
Selling The best Damn Air Suspension www.ridetech.com jon@ridetech.com (812) 482-2932 |
03-17-2009, 06:30 PM | #28 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
When you hard wire a 4- way Big Red airvalve into a digital controller, do you need a sending unit on every valve to make it function?
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 Last edited by 66chevy PROSTREET; 03-17-2009 at 06:30 PM. |
03-18-2009, 05:27 PM | #29 |
Junior Member
That depends on the controller.... the valves dont need a sensor in order to function, they only need a 12V source from a momentary switch
03-18-2009, 05:32 PM | #30 |
SOLD
thanks
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
03-22-2009, 05:48 PM | #31 |
Where can I find the electrical connectors (from power supply/switchbox) for the receptacles on the the Big 4-way? Do the controllers that you sell on the website have the connectors?
03-25-2009, 10:58 AM | #32 |
03-25-2009, 11:28 AM | #33 |
i found them @ my local parts store and jegs has them
"painless performance products" http://www.jegs.com/p/Painless/748014/10002/-1 |
03-25-2009, 11:49 AM | #34 |
Thanks! I appreciate that!
03-25-2009, 11:59 AM | #35 |
Wide n'Low
Here is another source for almost any connector you could ever need.
http://www.mouser.com/ If you search weatherpack, you will find a bunch.
05-12-2009, 09:54 PM | #36 |
I can attest to a daily driver needing 4 wheel control! I tried to do it the "cheap" way and now am ending up doing it the right/more expensive way.
Tony, by chance are you having any sales on your 4-way Analog control panel?? That is the last piece to my 8-valve setup.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
05-13-2009, 10:15 AM | #37 |
Junior Member
Irish... sorry man... sure not.
05-13-2009, 02:49 PM | #38 |
Sweet! Thanks Air ride guys just ordered the big 4way!
06-12-2009, 05:58 PM | #39 |
any other compressors on sale? I need one just not that big. Im setting up rear bags with a tank on my 67
1967custom |
07-31-2009, 09:27 AM | #40 |
What will I need to get the digital gauge to work? I got the big red valve block about 6 months ago and have just got everthing plumbed up. Now it's time to add gauge(s). Will I need a sending unit for each bag?
07-31-2009, 10:34 AM | #41 |
Jon@AirRideTech
yes sir you will need the gauge and 4 sending units
07-31-2009, 10:46 AM | #42 |
OK thanks!
08-15-2009, 02:40 AM | #43 |
Phone's ringin Dude.
Just bought my Big Red!!
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
10-12-2009, 09:36 AM | #44 |
Life, Be In It.....
Tony,
disregard PM. I got one on its wayThanks
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 10-13-2009 at 04:56 PM. |
11-22-2009, 04:30 PM | #45 |
Is this still on?
02-24-2010, 11:54 PM | #46 |
Im intrested the big 4 but I have stainless tubing that is 1/2 and I really want more of a height control. Not where it goes all the way up with a small tap of the switch. Could I still use the 1/2 tube and reduce it to 3/8 at the valves or do i need to go ahead and get 3/8 tubing aswell to meet my need?
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
02-25-2010, 11:43 AM | #47 |
Junior Member
If you are already plumbed in 1/2" tubing then keep it all 1/2. The fittings at the block are 3/8 so you will need to change to the 3/8 NPT if you have 1/2 NPT. The easiest way to slow your system down without having to change all of your hardlines over is to install a flow control valve between the tank and the valves. You can get those at pretty much any place that sells compressors or airtools... Grainger ect... BTW... those valves go off sale on March 1 st so jump in there man
03-29-2010, 01:53 PM | #48 |
dam tony is still around lol
i had the first s10 air bar on my 98 ss s10 he helped me a lot on s10forum.com
2011 CTS-V MODDED 2006 TRAILBLAZER SS TVS2300 BLOWER SOLD 2007 TRAILBLAZER SS 11.7@117 1.817 60' Wifes Daily |
03-31-2010, 04:49 PM | #49 |
Junior Member
This isnt Tony is it ? ha ha ha ha ha ha ha whats up Dog! been a long time!
03-31-2010, 05:05 PM | #50 |
ill see you at sema this year bro. That s10 ss sold about 9 months ago 32k miles for 12500 bucks. Air bar still in it.
