05-09-2021, 08:59 PM | #1 |
Do I need lowering trailing arm cross member?
Hey guys; i tried to search and get a strong answer either way, but no luck so i'm looking for some opinions. I'm working on a 1968 C10 short box and doing a static 4/5 drop with lowering springs, drop spindles and shock relocate brackets. So, do you think i need to swap out my trailing arm cross member with a new lowering style to allow more room for the driveshaft and pinion angle? And if i don't need it for a 4/5 drop what about a 5/6 drop? I probably don't need to, but i'm also leaning towards a c-notch.
05-10-2021, 12:06 AM | #2 |
67-72 parts collector,…
Re: Do I need lowering trailing arm cross member?
Not needed for a mild static drop like that.
But I do like them for the exhaust openings,... to help raise your exhaust by running it THROUGH the crossmember.
05-10-2021, 07:40 PM | #3 |
Not a real need for the cross member. Some folks will flip the brackets. You will need about a 3 degree shim for correct the pinion angle.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-10-2021, 08:29 PM | #4 |
Thanks for the response! Exhaust cut-out's was part of my plan so i'll just cut them out of the factory cross member.
05-10-2021, 11:42 PM | #5 |
I just moved them up one bolt hole and re-drilled the top set of holes.
Worked just fine. |
