06-12-2014, 01:37 PM | #1 |
5.3 with Boyd tank issues.
Given my DD is a BMW M3 and I dont drive like most around corners..
Ive noticed with 1/2 a tank if i hit a corner with some speed i get starvation issues. Anyone else notice a problem..? Like baffles were not installed. |
06-12-2014, 03:00 PM | #2 |
Re: 5.3 with Boyd tank issues.
You should be able to look at the bottom of the tank and see if baffles have been installled (distortion of the metal). How old is your tank? Are you running an internal pump? What is your fuel pressure set at?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-12-2014, 03:19 PM | #3 |
tank is 3mo old.. maybe
dont remember any distortion. Aeromotive 340lph intank pump. stock fuel regulator, i'll have to test it but.. as soon as the lines fill back up.. its back to normal. |
06-12-2014, 03:58 PM | #4 |
I would start by verifying the fuel pressure at the rail, although it does sound like a feed problem. Are you running the corvette FPR? When I talk about distortion, it's very minor, but on mine you can see where the baffles are welded to the bottom of the tank (I have the Boyds A1000 tank).
06-12-2014, 04:36 PM | #5 |
no stock 5.3 regulator on the intake.
not the 1000 the http://www.azproperformance.com/Boyd...ill-14003.html |
06-12-2014, 04:46 PM | #6 |
Does it have a return line? First thing is to check the fuel pressure.
06-12-2014, 11:29 PM | #7 |
Boyd 67-72 EFI tanks have 2 or 3 baffles in them.. you should be able to tell from the outside via just the vertical interior welding marks distorting the outside appearance just slightly....
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
06-13-2014, 06:30 AM | #8 |
Regular baffles control sloshing, but won't do a thing for fuel starvation beyond delaying it a half a second. Think how fast all the fuel can get to the other end of a normal baffled tank if you tip one end up a foot.
You need an intank sump (or external surge tank) like most factory efi cars have (the white plastic basket design is common). I have good results building a one or two quart container with a ~3/8" hole in a bottom corner to let fuel in. The ones I make run almost to the top of the tank. For over 300hp or extreme cornering I would use trap doors rather than a small hole. That coupled with the return line dumping back into the sump has worked very well for me.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
06-13-2014, 08:53 AM | #9 | |
06-13-2014, 11:03 AM | #10 |
3/8 feed and return nylon tube.
I'll tape a gauge to the windshield. its been running great, 100miles a day for 2 weeks. my OBD2 port has a problem connecting.. guess i need to figure that out and pull a code. Last edited by Windsma; 06-13-2014 at 11:09 AM. |
