Old 05-18-2021, 10:58 AM   #1
63C20stake
Question Straight 6 Engine Identification
I know this topic has a lot of coverage on this Forum and various others. However my particular 6 does not fall strictly into one set of specifications. Do i have a Frankenstein? Okay so I have a 63' C20 with a stake-side bed, the original owner told me when i bought it that it had a 292. However as I am replacing the clutch, and reading the manual my conflict begins. The Clutch currently in it is a 10" Diaphragm with the 168 tooth flywheel. My manual says a 10" Diaphragm did not come with a 292 but with a 230. It says the 292 only cane with a 12"coil. Next my gallery covers have a height of 4" signifying the smaller engine. My fuel pump is centered on the block, not offset forward. The motor Mounts are staggered with the passenger side forward (292). Finally the number on the block 3789404, comes up as a 292. What is going?
63C20stake is offline   Reply With Quote
Old 05-18-2021, 11:20 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Straight 6 Engine Identification
Definitely sounds like you have a 292. What probably happened was your clutch got replaced with a 10" instead of the 12"
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 05-18-2021, 09:33 PM   #3
63C20stake
But the covers having a height of 4"?
Old 05-18-2021, 11:11 PM   #4
cwcarpenter98
Post up some pictures. That would help out a ton in identifying what you truly have
Christian Carpenter
engine casting codes, identification, inline 6
