Old 09-29-2011, 04:25 PM   #1
nacho55
ls1 oil priming
Just thinking the other day that my 5.3 motor has been sitting in my project for almost 2 years and will probably be sitting a few more months before I fire it, so I was wondering if there was anyway to prime the oiling system before starting it again.
nacho55 is offline   Reply With Quote
Old 09-29-2011, 08:51 PM   #2
pat565
Re: ls1 oil priming
I have seen an article about this. Maybe in Hotrod?
Someone used a pail, electric drill running a SBC oil pump with a hose tied into a fitting into the block (I think)
Maybe try a search on google
pat565 is offline   Reply With Quote
Old 09-30-2011, 10:56 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: ls1 oil priming
GM uses something similar to the mityvac setup
http://www.mityvac.com/pages/products_fee.asp
dwcsr is offline   Reply With Quote
Old 09-30-2011, 11:28 PM   #4
67C10BUB
67C10BUB's Avatar
Re: ls1 oil priming
I just poured some Marvel Mystery in each cylinder and turned the crank by hand. Mine started up fine and has run great ever since.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-01-2011, 04:03 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: ls1 oil priming
a little wd40 in each cylinder, crank with the plugs out (no compression) to get a little prime, and you should be good to go. My engine sat for a while at the wrecker, then again on my engine stand for nearly 5-6 months. Fired up with one little *puff* to get the wd burned out...right on the first try.
I did check to make sure that there was no rust in the cylinders BEFORE all this, but the wd helped keep things easy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
