04-07-2002, 10:11 PM | #1 |
MSD Billet Distributor?????
been looking and reading about the MSD Billet distributors. i am just wondering if i will get any better spark (longer & hotter, or??) than i have now with a GM HEI with MSD 42,000 volt coil and MSD module (good solid spark to 9,000 RPM). this would the #85551 distributor with a blaster 45,000 volt coil and a 6AL (includes rev. limiter) ignition box. what ya all think????
'72 C-10 Cheyenne Super, 402/TH400, Bucket Seats, tilt, tach, AM/FM & shoulder harnesses and a ground up restoration |
04-07-2002, 10:48 PM | #2 |
"See the U.S.A....."
does your engine ever see 9Grand?
------------------ 1970 short bed fleetside
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
04-07-2002, 11:26 PM | #3 |
As long as your setup keeps the plugs burning clean,I wouldnt change it. MSD is nice stuff,but with the HEI,you can get parts anywhere. I have upgraded to a hot coil & module,& it made a diff over the stock pcs. If you need to, you can add the 6A box to your HEI........69 longhorn.
http://community.webshots.com/user/hotrodhorn |
04-08-2002, 02:15 AM | #4 |
your not going to notice any increase in performance since it's a street truck. What you will get is a better built distributor that should last longer due to the bearings and billit housing
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
04-08-2002, 08:19 PM | #5 |
The biggest advantage to the MSD distributor is the ability to PRECISELY control the total mechanical advance and even adjust it to match the initial timing that matches your motor. HEI is notorious for not having enought total advance and requires using the vacuum on a ported source to increase advance. This is not as accurate as using mechanical. It is possible to make a big cam idle and run good at part throttle by tailoring the initial and mechanical advance for WOT and using the vacuum at idle/part throttle to increase advance and smooth the power delivery.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
