04-22-2002, 10:00 AM | #1 |
Got 20's????
1 more inch
I did the flip kit on my 72 and I need to get the rear end up just one more inch. What can I do? Are 4X4 shackles shorter than 2wd? and if so will they fit? After the flip kit the rear sits exactly 1" lower than the front and I hate the uphill look. Are there any add-a-leafs that will work.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
04-22-2002, 10:13 AM | #2 |
its all about the +6 inches
Lifting blocks are inexpensive, and alot of parts stores carry them on the helf. Esp just a one or 2 inch block...probably no more than 30 bucks.
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-22-2002, 10:41 AM | #3 |
SKINNY TIRES RULE!
Hockey puck. (just kidding!)
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-22-2002, 10:45 AM | #4 |
Ummm,after a flip kit,a block will lower you more. On my longhorn,I did a flip on the rear axle,& relocated the brackets(moved down on the frame),approx 1 1/4" to get the height where I wanted. On the rear brackets I added a pc of 1/4" 3x3 angle to the bottom of the frame(bolted to the inside of the bracket to eliminate flex). You want to make sure & use grade 8 hardware,& pinchlock nuts.Good luck.....69 longhorn
http://community.webshots.com/user/hotrodhorn |
04-22-2002, 11:21 AM | #5 |
Post Whore
www.offroaddesign.com has a zero rate block that give you 1" of lift and it is center bolted to the spring pack for added strength.
------------------ 1969 C20 4x4 with roughly 6" lift and 35's residing near Rose Hill, Kansas Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-22-2002, 03:33 PM | #6 |
But when you flip a two wheel drive, the axle is on top of the springs and the block lowers it even further. I would either try and find a set of springs that hard more arch than the ones you have, run a taller tire in the rear, or drop the front 1 more inch.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
04-22-2002, 03:49 PM | #7 |
Or relocate the brackets,if the budget goes like mine does at times........69
04-22-2002, 04:03 PM | #8 |
GMC SHORT FLEET F/S
my wife asked for the same thing! lol
------------------ Charles W. Hein S. Williamsport PA imaindianoutlaw@yahoo.com REFRIGERATION TECH 1971 Rolling chassis FOR SALE 1963 Pontiac Tempest 1965 Pontiac GTO 1956 Pontiac 2 dr
CHARLES WADE HEIN HVACR FOREMAN. LEWISBURG U.S.P. |
04-22-2002, 04:09 PM | #9 |
What,1 more inch? hehe,mine did too.....I told her sorry,I never use it all!!!!!!!69
04-22-2002, 05:38 PM | #10 |
The shackles from a van would work, and are shorter.
72 C10 475HP 402BBC Yes, it's fun, but gas ain't cheap! |
04-22-2002, 06:46 PM | #11 |
Got 20's????
What year van? 73-87 would have wider leafs, so they wouldn't fit into the shackle right? Hey Longhorn, do you need to lower both the front and rear mounts? I've been thinking about that. Also I might get air bags for it just for helpers right now. What kind of brackets would I need to make? Where do I mount them?
04-22-2002, 06:49 PM | #12 |
oops, you are right other longhorn...I was thinkin he flipped it to raise.
04-22-2002, 06:57 PM | #13 |
Yes,I lowered both front & rear brackets. The fronts didnt need any bracing,but the rears I used a pc of 1/4" angle iron,(2 1/2 or 3",whatever fits the frame width). 3 bolts on the bottom of the frame,& 2 bolts to the hanger. I only moved them down 1 1/4".....now the longhorn frame is a little different,so you need to look see how the drop will affect the front hanger on yours. I upped the hole size to 7/16,& used grade 8 bolts ,& pinchlock nuts(lockwashers arent worth a sh*t on suspension stuff).I have run 10,000 mi since,& havent had any trouble. Good luck.....69 longhorn.
04-22-2002, 07:01 PM | #14 |
Longhornmail,you got me on "just pop the clutch" this morning! Hehe,I didnt read it all,though I was talkin about an auto trans....oops.......69
