Old 12-13-2010, 02:26 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Vent Windows
My vent windows are in horrible condition, the seals sucks, the metal "track" is rusted to hell, and the handles are pitted and loose as hell. What would be the best route to go as far as getting them to look and work like stock? Replace them as a whole unit? Piece by Piece? Or ditch the vents and go with the 1 pc kit? It will cost about $170 to "rebuild", $700 to replace, $600 for 1 piece.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-13-2010, 08:39 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Vent Windows
Replace the entire window assembly!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-13-2010, 08:49 PM   #3
SBTork
Garage wrench
SBTork's Avatar
Re: Vent Windows
I recently replaced mine with new assembiles from GM, and yes, they were expensive. But, they're worth every penny in my book.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 12-13-2010, 10:22 PM   #4
2badgn
Re: Vent Windows
I know u said that u bought them from GM but when I went to my local Chevy dealer for the weatherstripping bc I have aftermarket weatherstriiping that sill makes wind noise on highway, he told me that the weatherstripping for the vent windows was discontinued.
Dont know if weeatherstripping that has been sitting around for 25 + years is better than new aftermarket weatherstrip.
Some people said that if u use vent windows from later model truck- think 90 or 91 - that it solved the wind noise. Dont know if u have to change the wvent window also or if u can just change the to 91 weahterstrip and use original 80s vent windoe.
Please HELP- hate that wind noise
2badgn is offline   Reply With Quote
Old 12-14-2010, 07:25 AM   #5
PRattenbury
Re: Vent Windows
My doors are awful that way, too. The noise drives me batty.
PRattenbury is offline   Reply With Quote
Old 12-14-2010, 08:11 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Vent Windows
I was told use the newer ones,with the locks
and a slight bend in the vent frame will help get rid of the noise
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-14-2010, 09:53 AM   #7
Jonboy
Slots go on anything!
Re: Vent Windows
Some of the weatherstripping may be discontinued, but most is still available. The vent window assemblies are still available, there is stock in Lansing when I checked a couple of months ago.
I have always tried to pull the ones out of newer Suburbans in the pick a part. The newer, usually the better condition of the rubber.
1974 Jimmy- 5.3/4L80e/NP241
Old 12-14-2010, 11:27 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Vent Windows
Thats what i just did,vents, glass and seal etc mine in the 78 were done... Lucky the vents fit all the years they do now using 89's.
The track felts were worn/cracked and
side glass is much thinner,almost half?
That glass width difference could sure lead to a "air leak"
Lol my jimmys top corner felts leak air so bad can't tell if the vents are air leakin, but not drivin it now till spring anyway
John
Old 12-14-2010, 12:42 PM   #9
SBTork
Garage wrench
SBTork's Avatar
Re: Vent Windows
Yeah the some of the vent window weatherstripping is discontinued but I was referring to the brand new assemblies. They are still making those as the last one I got was made in May of this year.
-Adam
Old 12-14-2010, 04:13 PM   #10
allengator
allengator's Avatar
Re: Vent Windows
Anyone have the GM part # for the vent window assemblies??
I cant seem to find it online!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-14-2010, 04:27 PM   #11
Jonboy
Re: Vent Windows
RH is 15634472, LH is 15634472. The estimating software I am using shows that they may not come with glass. There are a couple of different designs of the glass, these assemblies would use the 85-91 style.
Old 12-14-2010, 04:56 PM   #12
allengator
allengator's Avatar
Re: Vent Windows
$237.07 from http://www.gmpartsdirect.com/
Not too bad.....
Allengator
Outta the Blue
Old 12-14-2010, 10:14 PM   #13
gchemist
gchemist's Avatar
Re: Vent Windows
Open the window. Does the weather strip have a smaller channel in it? If so, you can stop part of the whistle. Using a dull screw driver, slip the smaller channel edge over the vent window. It should seal both sides. Buy some clear silicon. Seal the area around the pivot bolt. I did this to my truck. I have no wind noise at all. Not even at 100 MPH.
Old 12-14-2010, 11:00 PM   #14
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: Vent Windows
Not discontinued, but on a national back order without any sort of ETA date from the factory.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 12-14-2010, 11:27 PM   #15
TimQ
Re: Vent Windows
Regarding the backorder on the vent seals...I actually ordered a set back in the summer...took almost two months to get them. Vendor told me everyone was out of stock at the time. Mine eventually came, so, someone must be making them just not fast enough I guess.
TimQ is offline   Reply With Quote
