Old 12-14-2010, 05:58 PM   #1
cor86
Blower motor fun
Hey guys and gals, I have a quick question for you. I did a quick search, and found little, so here goes: I just got home from work today and the blower motor won't shut off, even after I take the keys out of the ignition. The speed selector switch does nothing, either. It is stuck in high. I finally pulled the plug on the motor, to get it to quit. I assume the problem is with the relay, but wanted to make double sure. I would rather sit in the warm and type, than go outside with a multimeter. Can someone confirm this? It looks like they are $10, so I will give this a day, but I really don't like the idea of popping the hood to turn it on and off. Thanks for your help!
cor86 is offline   Reply With Quote
Old 12-14-2010, 06:13 PM   #2
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
Re: Blower motor fun
sounds like you have an issue of bare wires somewhere if its running after you turn the ignition off.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 12-14-2010, 06:42 PM   #3
MrDude_1
its probably the relay being stuck.
this is off the top of my head, but i believe the blower circuit is constant power, not ignition... only the trigger circuit for the high speed relay is ignition power..
of course, we both know the only way to be 100% sure is to get a meter out.
MrDude_1 is offline   Reply With Quote
Old 12-14-2010, 08:57 PM   #4
cor86
DING, DING, DING...We have a winner. Best $10 I have spent today. Now I won't have to mess with it in the morning. In true hillbilly fashion, I just pulled the plug from the old relay and plugged in the new one. It obviously doesn't have to be grounded, and isn't going anywhere anytime soon. Kinda reminds me of a new TV sitting on top of a non-working one. I picked up a new blower motor/fan combo, for the 88-98 trucks, while I was at it ($26, but made in china). Probably install that and bolt the new relay in tomorrow. I hope this helps someone in the future, and I will report any advantages of the later model motor, as well.
Old 12-15-2010, 07:20 PM   #5
cor86
Just a quick update, I got the relay bolted on! Woohoo! Also got the new blower motor in. It came from Autozone, and was supposed to be the Continental, but the box says VDO. Made in China, but came with a wheel and was only $26. Part # is PM129. It is like I added another speed after high. Not sure if my old one was that worn out, but I did see a big difference with that one, which came out of a 90 Suburban that I parted out. Anyways, I know it has been covered before, but thought I would share my findings. It is a highly recommended upgrade! Just wish I wasn't so cheap. and went with the Delphi unit.
Old 12-15-2010, 10:43 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
I also put a 88-98 blower motor in my 87 cause the old one was squealing when it got cold outside(and I had one lying around). Looking in the motor hole I know why(full of 20 years of crud) Anyway the new motor is great but I didnt see any noticable fan improvement?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
