Old 01-17-2019, 06:10 PM   #1
spudder
Active Member
Tach Project
I'm in the process of installing a tach from a larger GMC truck in a '65 C10. I've pretty well got the installation figured out, but the wiring has me a little confused. Most every tach I've encountered has two wires for the tach to function. 12 volt power and another that goes to the - terminal on the distributor or tach terminal on HEI.
This tach is secured in the can by 3 studs with only 1 stud being insulated from the case and no spade terminals for the wires.
The case is stamped AC Div. GMC. I know the tach came out 0f a '70s-''80s big GMC gas burner.
Anyone know anything about this style tach?
Any help appreciated!
Just looked at the tach and found a date October 13,1977
spudder is offline   Reply With Quote
Old 01-17-2019, 07:24 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Tach Project
Oh ya, that's your basic 12-2 Alpha-Delta Charlie right there. Yep.
Old 01-17-2019, 07:30 PM   #3
ray_mcavoy
Re: Tach Project
I haven't seen one exactly like that before, but GM did have some tachometers that used a simple 1-wire hookup to the negative side of the coil (no connection to 12v power).
Here's a link to an old GM tachometer service bulletin --> http://www.oldsmobility.com/img/pdf/...air_Manual.pdf
See the non-transistorized "Group 1 inductor type" tachometers as described on pages 12 through 14. The internal schematic is shown in figure 8 on page 27.
ray_mcavoy is offline   Reply With Quote
Old 01-17-2019, 07:31 PM   #4
Nanook
Nanook's Avatar
Re: Tach Project
Spudder,
I have used a similar style tach in the past.
I believe that the insulated terminal goes to the negative side of the coil/distributor and one of the two case studs goes to ground. (Doesn't matter which one)
No 12 Volt power required.
Nanook is offline   Reply With Quote
