06-27-2020, 11:09 AM | #1 |
86 Suburban daily driver
I picked this up May, had kinda been looking but not too serious. It had the right look, and the right attributes so I brought it home with me. I grew up riding around in the back of these things, so I guess I'm re-living those memories!
86 Suburban, came from Oklahoma and I haven't been able to find any real rust on it yet (those in the upper midwest and rust belt will know exactly what I mean by this). Had a lot of good things already done to it, and my plan is to refine it and then drive it everyday. We'll see how that evolves with time. Main needs are to be reliable and comfortable for the whole family.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-27-2020, 11:21 AM | #2 |
Re: 86 Suburban daily driver
It has some good things going for it, and it also has some needs after 34 years.
Here's what I've been able to ascertain it has had done to it: - 4/6 drop. - McGaughys spindles and MaxTrac springs - Flip in rear (no notch) - At some point it had a remanufactured 350 - Weiand Street Warrior intake - Holley 4160 carb - Ceramic coated headers and some dress up stuff. - Jeep steering shaft - Boss 338 wheels, 18x8 and 20x10, 255/45r18 in the front and 295/45r20 in the rear - drilled and slotted rotors on the front - phantom billet grille....not sure what to think of this yet
06-27-2020, 11:30 AM | #3 |
First order of business will be to check things out and start fixing stuff. I re-packed the front wheel bearings, replaced the rear wheel bearings, and drained the rear diff oil. I noticed a spider gear that had more run through it than just 80-90, so that needed attention. I evaluated the cost of new spider gears, and ultimately decided to replace it with a Quick Performance posi. I also did all the bearings in the diff and put in a crush sleeve eliminator. The driveshaft had bad u-joints, so those were replaced too.
06-27-2020, 11:37 AM | #4 |
The front suspension still needs work. Someone bashed the driver's side lower control arm pretty hard and the bushing is mostly popped out, so I bought a replacement control arm and I'm getting that ready to go now.
06-27-2020, 01:13 PM | #5 |
The rear suspension is where I need to focus on in the very near future. It has a flip, but no notch so the axle SLAMS the frame on a very frequent basis, and this won't do. The picture below shows 1.75" of clearance, but when it is down on the ground with all the weight on it is more like 2 fingers clearance. I haven't been able to find any commercially available notches, which is fine, so I'll build one and weld it in. At the same time I'll be removing the flip brackets and welding on new spring perches and centering the tire in the rear wheel well like it should be. There are air shocks that do not function, and looks like one of the mounts on the frame has been ripped off the frame and cobbled back on. Extended shock mounts will also be fabbed up and I'll run some normal shocks of a decent length.
06-28-2020, 12:02 AM | #6 |
Rad Burb! Where'd you source the control arm?
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
06-28-2020, 07:50 AM | #7 |
Thanks!
Control arm was used off Ebay.
06-28-2020, 08:09 AM | #8 |
So as could probably be expected, nothing worked. Power locks didn't work, and the front 2 windows would eventually go down, but the rear ones wouldn't. Some time with a multi-meter let me to conclude that power was getting where it should, but switches were bad. I replaced both power lock switches and one of the solenoids, and did some lube-ing and now all 5 doors lock and unlock reliably with the switches. Windows were a similar treatment, only the driver's door window switch worked so the rest were replaced and I'm waiting on 2 window motors and then all the windows should work too. I still plan on putting relays in the doors for the windows to work quicker, but haven't gotten to that yet. All the rubber and glass runs also will need to be replaced too.
06-28-2020, 09:04 PM | #9 |
Today I was able to tackle the oil cooler....and get rid of it. It leaked just like they all do and it felt good to get rid of that particular leak and clean up the bottom of the engine just a bit.
Since I had the grille out I took that opportunity to install the temperature sensor for my compass/temperature rearview mirror. I add these mirrors to all of my projects, love 'em!
06-28-2020, 10:56 PM | #10 |
Has that vehicle always been a 1/2 ton? I didn’t know that the half tons got an engine oil cooler on the 350.
I just redid the oil cooler lines on my 83 454 Burban. I enjoy the build thread! |
06-29-2020, 09:31 AM | #11 | |
K https://www.gmheritagecenter.com/doc...t-Suburban.pdf
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-29-2020, 09:48 PM | #12 |
Yep, this one has always been a half ton.
Two steps forward, one step back. Rear window motors showed up, so I went to installing them. AC Delco, good old USA made parts...ah....nope - not anymore. First problem was that the stamped brackets bolt holes didn't line up very well. When "forced" into place, they put such a bind on the motor that they didn't work. The fix for that was to drill out the holes so they could be bolted together and not induce a bind. First one in, and amazed with how fast it goes up and down. I may not need to do the relay mod after all! 2nd door, everything was going really well until the duct tape I was using to hold up the glass let go, and it came down quick and broke the glass. Anyone know where to source factory dark tinted glass?
06-30-2020, 03:42 PM | #13 |
Nice looking burb project.
06-30-2020, 09:02 PM | #14 |
Dude, that sucks with the glass. My whole thing with these trucks is that since somebody else wore it out, I'm trying to wear it back in – so to speak. I get so frustrated when my efforts produce damage. My best idea is for you to watch Craigslist, Facebook Marketplace, maybe even Offer-up. There always seem to be a few Suburbans being parted out.
07-02-2020, 09:28 AM | #15 |
Cool project..You are getting busy.
07-02-2020, 06:38 PM | #16 | |
Cool family ride for the record!
07-02-2020, 06:45 PM | #17 | |
07-02-2020, 06:59 PM | #18 | |
Thanks for the heads-up, and I'm already on it! I already measured the space between the top of the diff and the floor, and used that as my measurement as to how deep the notch reasonably should be. I want to cut as little as necessary because hooking up a trailer is still important to me.
07-02-2020, 07:21 PM | #19 | |
07-06-2020, 08:45 AM | #20 |
I scored a lightly used Holley transmission crossmember over the weekend. My exhaust (on the passenger side) is the lowest point on the truck, so that will make it nice to tuck that up when I get around to installing it!
07-12-2020, 09:57 PM | #21 |
Was able to get some more work done on the suburban over the weekend. Put in a new window to replace the one I broke. I picked up some steel for the notch, now just need time to get that in the works. I did get my phone up underneath to snap some pictures for those who wonder if you can do an axle flip on a suburban without a notch....without it, you have a cool inch between the axle and the frame....which isn't enough.
I'm also in the planning stages of deciding how I'm going to make new shock mounts that allow for longer shocks. Need to improve the ride on this thing and these things are what it will take!
07-12-2020, 10:01 PM | #22 |
I also spent some time with a buffer. Now, I don't really know what I'm doing when it comes to buffing...and it shows. I used too much compound on the first fender and not enough elsewhere, so I really need to go over the whole thing again but I didn't feel like it after round 1, so that'll be another day. Significant improvements though from what I did do! Constructive criticism is welcomed here....
07-12-2020, 10:09 PM | #23 |
And lastly I've cleaned up some wiring. I have no idea what possessed the last stereo installer to do what they did, but it's fixed now. I have a confession, I *never* use butt connectors. I showed the Suburban to a friend last week, who noticed the butt connectors and commented that he couldn't believe I would even drive it like that! Ha, so I had to fix it!
The power wire to the radio was 36" long, had four butt connectors (both red and blue ones), and the wire was wrapped around the radio fuse and pushed in the slot. Oh man! They completely bypassed the original radio wire that already ran to that fuse and was right there. The radio is back in and working properly now. I will come back and make an 18 gauge plate to replace the plastic one in the radio install kit, and I will also clean up the hole in the dash that was chopped in there before installing my nicer bezel.
07-13-2020, 10:59 PM | #24 |
Nice fix and great thread on the truck. The wiring on these trucks are always funny, the last two trucks I had have given me heart palpitations when I started working on them.
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
07-16-2020, 06:41 AM | #25 |
Looks like a fun project,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
