Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-09-2021, 03:50 PM   #1
pdxhall
pdxhall's Avatar
stripped door hinge nuts
I've got 2 nuts on the cab side of the hinge. Both are the main bolts on both top and bottom hinges. What are my options for repair? Can I drill and tap the cage nuts or cut and replace?
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 05-09-2021, 04:01 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: stripped door hinge nuts
could you do helicoils?....pics of what your dealing with might help
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-10-2021, 06:29 AM   #3
MP&C
MP&C's Avatar
In some cases there is a sheet metal cage that surrounds the hinge nuts to hold them in place, and this cage is held in with three to four spot welds. If you can drill out the spot welds to release the cage, you can remove the nuts, replace, repair, or fabricate new ones, and then reweld the cage back in place.
Looking at this marked up copy of your picture, look in the areas of the red circles for spot welds. These should be what is holding the cage in place.
Robert
MP&C is offline   Reply With Quote
Old 05-11-2021, 11:37 AM   #4
twotrucks
Junior Member
I stripped one of the nut plates on the cab side and fixed it using a M10x1.5 bolt. I did run a tap through the nut plate first, it tapped very easy and worked fine.
twotrucks is offline   Reply With Quote
