12-02-2014, 04:00 PM | #1 |
I'm just glad to be here!
1987 Fuel Sender Conversion for LSx Swap
Here is how I set up my fuel system for my current LSx Swap on my '85 GMC. I will be using a return style system. The engine is from a 2000 5.3 from a GMC truck. The engine is stock except for headers and a cold air intake.
I bought a new '87 tank and sender from Spectra Premium from Amazon.com. Tank, 16gal (SWB) PN GM11B Sender, Driver side tank: #FG05M -OR- Passenger side tank: #FG05N For the pump I purchased a Bosch #69225 (same as an ACDelco EP381) from Rockauto.com. The kit includes clamps, fuel line, isolator, wiring pigtail and clamps for install. I also purchased a new Strainer, Spectra Premium #STR01 (required for Fuel Pump Warranty) from Rockauto.com. I did not know the sender kit had one already with it...oh well, it was just a couple of bucks, now I have a spare... The fittings I used are: Jegs 3/8” tube to -6 Male AN Fitting (#100551) Earl’s 5/16” tube to -6 Male AN Fitting (#165056) I used one Earl’s and one Jegs because of cost, I saved a few bucks & Jegs did not have the 5/16” fitting (the Earl’s 3/8” tube to -6 Male AN Fitting is PN#165006, if you have to have both fittings the same brand). I got these thru Amazon.com. Here are pictures of the components: Sender: Fuel Pump, Strainer, and Fittings:
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-02-2014, 04:09 PM | #2 |
Re: 1987 Fuel Sender Conversion for LSx Swap
First step in the conversion is to modify the tubes on the top of the sender for the -6 AN adapter fittings. The small bulge on the end of the 3/8" line and the 5/16" line need to be removed.
Cut them off as close to the bulge as possible, but the OD of the line must not be enlarged or the fitting's ferrule will not fit correctly. Deburr both the inside and outside of the lines once they are cut off. Here is the Jeg's Fitting (for the 3/8" line) taken apart. Slide the red part of the fitting over the end of the 3/8" line followed by the brass ferrule. Screw the blue part of the fitting into the red part and tighten per mfg's directions to crushe the ferrule and make the seal on the tube. Here is the assembled fitting on the sender: Now, repeat for the 5/16" line. The Earl's fitting is a little different shape on the tube end, I needed to bend the support tab on the top of the sender down off the tube before putting on the fitting. Once the fitting was on and tight, I bent the support back up and around the tube. Here is the completed fittings on the top of the sender: Leave the center tube (1/4" diameter) alone. Use a regular hose and hose clamp to route a vent tube up and out of the way on this tube of the sender.
12-02-2014, 04:17 PM | #3 |
Next is the install of the pump on to the bottom of the sender. My pump kit had all the parts needed to attach the pump as did the sender kit I purchased. I used the hose and clamps from the sender kit. The clamps in that kit are the "fuel injection" style clamps as opposed to regular worm gear clamps that came with the pump. Slide the black rubber sleeve over the pump and place the black rubber cushsion on the base of the sender. Slide the hose and clamps on to the pump, then install the hose to the tube of the sender and seat the pick up end of the pump in the cushsion at the base of the sender. Tighten the clamps. Press the strainer onto the pump thru the hole in the base of the sending unit. Connect the wire pig tails for the pump motor.
Here is the pump installed on the sending unit: Completed pump and sending unit: From here, just intall the pump into the tank with the new o-ring and lock ring that came with the sender (or the tank). Both had them... Connect your hoses to the supply and return fittings and the vent hose. Install the tank in the factory location.
12-09-2014, 02:56 AM | #4 |
I thought I read on the mfg's website that those tube to AN fittings were not for high pressure applications. I believe they were only rated at 35 psi or something like that. That's the sole reason I did not go with those. They look good though. I'll post some pics up of my fuel sender set up.
12-09-2014, 11:04 AM | #5 | |
https://holley.com/products/Plumbing...ts/AT165056ERL It is rated for 250 psi. In my opinion the LS fuel system is not really high pressure. It only runs at about 58 psi. Yes, that is higher than carbed fuel systems, but many other systems operate a much higher pressures than that and use the AN/tube adapters.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 12-09-2014 at 11:09 AM. Reason: opinion... |
12-09-2014, 01:08 PM | #6 |
I've must have been looking at these....nice write-up btw.
http://www.summitracing.com/parts/ea...6erl/overview/ |
12-09-2014, 01:47 PM | #7 |
Nice write-up. Were you planning on using the same tubing to AN adapters for the stock fuel line and running a short section of FI hose / braided line between the two or were you doing something different?
12-10-2014, 09:29 AM | #8 |
12-10-2014, 04:01 PM | #9 |
LS-K - That looks good. Probably the same amount of work as mine too. What's funny to me, is the part number you linked to Summit is the same part number on the Holley (Earl's) web site that lists them for 250 psi.
NorCalAnthony - They make a specific adapter fitting for the GM fuel lines on the rail. Between the tank and the rails I will be using braided line. Here is the part numbers for the fuel rail adapter fittings: Supply Line: http://www.summitracing.com/parts/rus-644120/overview/ Return Line: http://www.summitracing.com/parts/rus-644110/overview/ I used the black ones. 644123 (Supply) & 644113 (Return)
12-11-2014, 04:04 PM | #10 |
Sweet write up. I have a fresh 5.7 I should put in my truck, it's been put up in storage for awhile now I need to put it to use.
12-11-2014, 04:17 PM | #11 |
Everything is just plug and play as far as the pump to sender goes? And then the two wires coming from top of the sending unit which I assume is a ground and a switched 12v?
12-11-2014, 06:53 PM | #12 |
Yes sir the pump just almost falls into place. There are 3 wires coming out of the connector at the top of the sender. Black is to Ground, Gray is the Power to the Pump and the Purple is the sender to the gage.
**(I might have the Gray and the Purple switched. I will check and repost to confirm.)**
12-11-2014, 07:09 PM | #13 | |
12-12-2014, 10:39 AM | #14 | |
Compare the 2nd picture in post #1 of the tubes on the sender to the tubes on the LS fuel rail and you will see the differences I am trying to explain.
02-13-2016, 10:30 AM | #15 |
This should be a sticky. Great information for LSx swappers.
My question is, do you really need to convert the return line into a high pressure line?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
02-13-2016, 04:15 PM | #16 |
My truck already has the spectra GM11B tank. It does not have any baffle inside. Are you sure this tank is for EFI?
02-13-2016, 06:17 PM | #17 |
The spectra GM11C might be the 16 gallon EFI tank?
02-13-2016, 10:35 PM | #18 |
I basically did the same thing expect i used an 87 suburban tank with ep381 pump, you dont need baffles , as long as you dont run it low low on fuel. My fittings havent leaked any T all
02-15-2016, 10:24 AM | #19 | |
02-15-2016, 10:30 AM | #20 | |
Most push lock hose and fittings are rated to at least 200psi and that could be a simple hose to make up with -6 JIC fittings (same as -6 AN fittings) that don't even use hose clamps. Having the -6 AN male to 5/16" tube fitting on the sending unit is just extra safety against a hose and clamp leaking.
02-15-2016, 10:17 PM | #21 | |
02-15-2016, 11:53 PM | #22 |
Nice suburban tank. How many gallon is it?? I found a 1991 40 gallon suburban tank on rock auto I was thinking of trying.
02-16-2016, 06:33 PM | #23 |
thank you for doing this thread. ill be using this info real soon
1967custom |
05-15-2016, 02:57 AM | #24 |
Nice write up! your procedure and write up are almost exactly what i had envisioned in my head. it is very nice to see actual photos tho.
What fuel line are you using? i know you said it was braided but do you have a source and part number? i shop almost exclusively at JEGS for the simple reason they have free shipping and are usually a buck or two less than summit. What fuel tank switching unit (under cab) are you using? source? I am installing all this in a pre-FI truck so i gotta make harnesses from the sending units to power source. I am hunting up detailed info on the HOT WIRE 'kit'. this looks like no fun at all! I am planning to use the corvette filter/regulator on my swap for simplicity reasons. I am planning (if it will actually work) to use aftermarket fuel rails so i can have a single fuel line from the reg to the rail to keep things less clustered. but i dunno yet if the aftermarket fuel rails are compatible with the truck intake manifolds. I think the aluminum intakes manifolds sure look cool, but my wallet doesnt think than the expense of the intake manifold for the use of cheap fuel rails is worth it. -Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
05-16-2016, 10:11 AM | #25 | |
My went into a pre-FI truck too, but only with a single tank. Can't help you there...As for the wiring, I used the stock wire for the Fuel Level gauge that ran down to the tank. I ran the fuel pump power wire from a relay on the fender well and followed the sender wire from the fuse block plug on the firewall down to the tank/sender. Simple. Hope that helps. My son just swapped pumps to a Walbro 400, did not have to change anything except the base that supports the pump. Had to cut that off and use a hose clamp to secure it to the hanger rod. Getting ready for Turbo upgrade.
Tags |
fuel pump, fuel system, lsx, swap |
