05-02-2022, 02:11 PM | #1 |
doing an ls swap in my 69 c20
I hear the stock 5.3 oil pan won't work (crossmember). any recommendations for an oil pan that will work?
05-02-2022, 02:26 PM | #2 |
The Older Generation
Re: doing an ls swap in my 69 c20
Moving to LSx Swaps Forum. LockDoc, Moderator -
05-02-2022, 03:26 PM | #3 |
It was my understanding that the truck pan would work. It does depend on your motor setback /placement. However, it hangs down several inches below the front cross-member. If you are running stock height or a 4X4 it will not likely be an issue. If you are going low, I wouldn't recommend the lowest part on the underside of your truck be the oil pan.
I used the GM pan sold just for conversions. Comes with the dipstick and windage tray. It's a nice piece. This pan will be close to even or sightly above the lowest part of the cross-member. I will get you a picture later today. |
05-03-2022, 06:58 AM | #4 | |
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
05-03-2022, 09:56 AM | #5 |
Blue 67
It worked for me. I modified my own motor mount saddles which brought my engine up about 1" and that made the stock oil pan at the line with crossmember. I have pictures on my build thread.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
05-03-2022, 09:59 AM | #6 |
Many thanks to you both- I'll check ebay. I'm not lowering it- like the high ride.
Scott |
05-03-2022, 10:00 AM | #7 |
I'll have to find it- thanks- will be cheaper than 200 bucks for the new pan.
05-04-2022, 05:18 PM | #8 |
low n' slo
if your not lowering it, you should be ok with the stock pan if its from a truck. the only issue is it hangs below the front crossmember, which shouldnt be an issue if its not lowered
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Thread Tools | |
Display Modes | |
