05-27-2022, 01:43 PM | #1 |
Torque Converter Recommendation
In a related thread I asked a question about torque converter rattle. It looks like I'm going to have to separate the engine and transmission, so I'm going to replace the torque converter while I've got it apart, whether that proves to be the problem or not.
Here are my vehicle specifications: 5.7 Vortec, HT383 cam (288/308 duration), Quadrajet, HEI, 9.5:1 compression, stock TH350, 3.73:1 gear ratios, 12.5x33 tires. Mostly driven around town. Any recommendations for a good torque converter?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
05-27-2022, 03:08 PM | #2 |
Re: Torque Converter Recommendation
I'd look for something around a 23-2500 stall.
05-27-2022, 07:43 PM | #3 |
Do you have a preferred brand?
05-27-2022, 10:15 PM | #4 |
I just get them from Transtar for my builds, but I don't do anything high performance, mostly stock and some occasional HD and towing stuff
05-28-2022, 10:24 AM | #5 |
I have an FTI in my truck. It's been fine.
05-28-2022, 10:24 AM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I've had good luck with Jegs converters...Have you looked at your flex plate? Sometimes them things will crack around the bolt circle and make rattling and knocking noises. https://www.jegs.com/i/JEGS/555/6040...rque+converter This one has a little lower stall but is $60 more expensive. https://www.jegs.com/i/JEGS/555/60402/10002/-1
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-28-2022, 12:21 PM | #7 |
I'd pick the 2nd one
05-29-2022, 09:16 PM | #8 |
I've used Yank and Circle on my hot rods and like them a lot. They pretty much drive like a stocker until you nail it. If you contact them make sure you have all your engine and drive line details in hand because they will want to know.
Not cheap but good. |
05-31-2022, 06:29 PM | #9 |
driving is in my blood
HT383 cam is puny, you basically have a stock 350. I'd use a stock convertor myself. Had a 2300 stall on a previous truck and hated it for a daily driver.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-31-2022, 09:47 PM | #10 |
Puny? That's kind of harsh... How about "mild"?
06-02-2022, 05:14 PM | #11 |
I dunno, I think 383 and a tim allen grunts play in my head.
But yes, mild is acceptable haha.
06-02-2022, 06:16 PM | #12 |
Puny for a race car. I ran a smaller cam in a 400 I built a few years back and it pulled like a freight train up to around 4500 when the trans shifted. If I remember the specs correctly it was a 400 block, .030 over, flat top pistons with 598 stock(ish) heads that I had 1.6 exhaust valves put into and a mild polish on the ports. Compression was about 9-1, cam was a comp 268. running an edelbrock 650 carb. Not all engines built have to run up to 7k
06-02-2022, 11:30 PM | #13 |
With 3.73 gear and 33 inch tall tire and mostly town driving I would stay with a converter closer to stock. 65 mph will be about 2000rpm, most of your driving would be below 2000 rpm. Converter would be slipping most of the time making it feel like you have less power and get worse millage.
06-03-2022, 05:17 PM | #14 |
A comp 268 is much larger then an HT383 cam. HT383 doesn't even have 200 @.050 intake duration, its smaller then a stock LT1 cam.
06-04-2022, 09:01 PM | #15 |
I would stick to a converter with an advertised flash around 1,600-1,800 RPM. You don't want the converter slipping still, when you're into your peak power building RPM. Or, could add a bit of camshaft and run a higher stall converter. I run a 2,800 stall converter and love it.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
Thread Tools | |
Display Modes | |
