Old 08-03-2004, 10:35 PM   #1
low 84
low 84's Avatar
are 10 bolt and 12 bolt drums the same?
anybody know if the drums on 10 and 12 bolt rearends are interchangable?
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 08-03-2004, 11:05 PM   #2
ocbaud
Garage Queen Material
as far as i know, yes they are..... axle wise. now the fittings MAY be different.
but what do i know haha
ocbaud is offline   Reply With Quote
Old 08-03-2004, 11:07 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Axle size has nothing to do with the drum size. It's according to what code you have, such as JB1, JB3, JB5, JB6, etc. There are two sizes on C10's. 11 x 2 and 11.15 x 2.75.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-03-2004, 11:15 PM   #4
Destructo
I swapped them on my K10, no problems. I also swapped all the other hardware too, make sure your brake shoes and drums match.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-03-2004, 11:57 PM   #5
low 84
low 84's Avatar
so mike, if i measure the shoes on both rears and they are both the same width , then the drums should swap, right?
'05 1500 Crew Cab
RIP
Old 08-04-2004, 12:22 AM   #6
swervin ervin
Right.
Old 08-04-2004, 12:29 AM   #7
low 84
low 84's Avatar
cool, thanks!
'05 1500 Crew Cab
RIP
Old 08-04-2004, 01:26 AM   #8
BaggedC10
Under construction!
BaggedC10's Avatar
Yep. I swapped drum brakes from my 10 to 12-bolt rear end.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 08-04-2004, 02:13 AM   #9
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I'll third that info, I'm in the middle of switching brakes from my 86 C10 to my 76 C10 frame, 10 bolt to 12 bolt. Everything bolts right up.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 08-04-2004, 10:06 AM   #10
low 84
low 84's Avatar
awsome, looks like all i have to buy is some fluid and a u joint
'05 1500 Crew Cab
RIP
