Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 07-08-2013, 12:21 PM   #1
doobiebro
doobiebro's Avatar
63 C-10 Panel wiring harness
Hello there...
Need to replace the complete wiring harness on a 63 panel I'm working on and would like to know what wiring harness you guys are using? I have used American Auto Wire in the past (60-66 Chevy truck - Classic Update Series) for a 60 step side I own and would like to use it again but no sure if it will work for a panel truck. The kit cost a pretty penny so I need some imput before I pull the trigger...Called AAW and the sales rep says it should work but he was not convincing. I know the cab is the same but the rear body and truck chasis not sure.... I also know the kit comes with long enough wiring for different truck bed applications. Please help fellas...
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 07-08-2013, 01:11 PM   #2
Clyde65
Clyde65's Avatar
Re: 63 C-10 Panel wiring harness
Call AAW, they will build it to your specs. length accessories etc.
You will only need extra wire for brake/tail lights, dome light and fuel sending unit right?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-08-2013, 11:21 PM   #3
MikeS.
MikeS.'s Avatar
I used AAW on my 63 Burb without a problem.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 07-09-2013, 05:13 PM   #4
doobiebro
doobiebro's Avatar
thanks for the answers I needed to know....pulled the trigger and ordered the kit
