Old 10-31-2019, 04:17 PM   #1
56HOTRODDER
Barn door latches
Does anyone know of a replacement / alternate part for the striker for the left hand barn door of a 1990 suburban? I only need that one striker and can't find anyone parting a burb willing to sell such a small item . I suppose I could get one welded up but was trying to avoid that route. Thanks
56HOTRODDER is offline   Reply With Quote
Old 11-02-2019, 08:11 PM   #2
v30crewcab
v30crewcab's Avatar
Re: Barn door latches
pretty sure the vans use the exact same ones. should be easy to find at the junkyard.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-03-2019, 08:53 AM   #3
56HOTRODDER
Smile Re: Barn door latches
Thanks ,that's just the kind of info I was looking for. I'll check it out
Old 11-23-2019, 04:34 PM   #4
69_hafton
Sleep-Deprived
69_hafton's Avatar
Anyone confirm this yet? I'm needing some too and I'm guessing the van would have to be a similar vintage?
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 11-23-2019, 08:22 PM   #5
BigBird05
Have you checked with the dealer? They might suprise you.
BigBird05 is offline   Reply With Quote
Old 11-24-2019, 10:57 PM   #6
69_hafton
Sleep-Deprived
69_hafton's Avatar
Thumbs up Re: Barn door latches
No, just got it so I'm just making a list and info searching. Hadn't thought about the dealer, but I'll give them a try
350/350 - 6" Lift
Old 11-28-2019, 01:12 PM   #7
v30crewcab
v30crewcab's Avatar
I just looked thru my stuff, and confirmed the van one is identical. I have a van and a sub here to compare.
71 longbed 5.3 4l80
Old 11-29-2019, 05:29 PM   #8
69_hafton
Sleep-Deprived
69_hafton's Avatar
Thank you, that may help with the search. Dealer said NLA to everything I asked about
350/350 - 6" Lift
Old 12-02-2019, 10:57 PM   #9
56HOTRODDER
I was in an older junkyard today and confirmed the Chevy vans have an identical latch loop.older 70s are a little different but look like they may also work . Thanks for the tip.
Old 12-05-2019, 09:06 PM   #10
v30crewcab
v30crewcab's Avatar
the actual bottom latch in the doors are the same also between the van and sub rear doors.
71 longbed 5.3 4l80
