02-27-2018, 03:14 PM | #1 |
Quick question for ignition wiring gurus
My first time installing a complete wiring harness and I’m a little stuck. I’m putting a AAW classic update harness into a truck with a pertronix igniter unit in the distributor. The instructions say to run the pink wire (12v) to the positive side of the distributor cap. I’m assuming I just run it to the + side of the coil and hook up the red wire from the pertronix to the + coil also?
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
02-27-2018, 04:29 PM | #2 |
Re: Quick question for ignition wiring gurus
That sounds correct. There's an obvious typo as there is no wire connection to the distributor cap. Depending on what Pertronix unit you have it may want 12 volts or 6 volts.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-27-2018, 04:58 PM | #3 |
Sounds like instructions for a H.E.I.
http://67-72chevytrucks.com/vboard/s...d.php?t=740665 |
02-27-2018, 10:19 PM | #4 |
Here's a link of the instructions. I talked to AAW and they said the harness will work wit the Pertronix unit as long as it is straight ignition 12 volts which Pertrnix verified and said no resistor is needed.
https://www.americanautowire.com/PDF...20IN%201.0.pdf
03-01-2018, 12:20 PM | #5 |
Anyone have thoughts on this? I don’t want to fry anything if I hook it up wrong...
03-03-2018, 10:44 AM | #6 |
Anyone?
03-03-2018, 11:27 AM | #7 |
Personally I would eliminate the Pertronix unit and go with the HEI. I feel the HEI is a more reliable unit
03-03-2018, 11:32 AM | #8 |
I would if I wasn’t doing a stock restoration plus it’s a 4x4 truck so I don’t really have the room
03-03-2018, 11:39 AM | #9 |
03-03-2018, 12:35 PM | #10 |
I'm running a Pertronix Ingnitor III module because I wanted to run a stock body distributor cap. I'm using an M&H harness that I ordered custom without a resistor wire.
Presuming you have eliminated your resistor wire or have otherwise provided an unmodified 12V ignition path, just follow the hookup instructions and all will be fine. If you have a tach you might notice it reads high at low RPM due to the multiple spark feature.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-03-2018, 02:17 PM | #11 |
The HEI will fit in a 4wd unless your body mounts are trashed. I just installed one in a 72 K5 for a customer. I can get my finger tips behind the cap. It's tight but it clears.
03-04-2018, 09:28 AM | #12 |
Your wiring is correct. 12v to coil +. Pertronix connects there as well.
I know guys have had issues with pertronix but i personally have one in a chevelle- going on 3rd season with no issues. And when I was a kid my dad installed one in a gto when they first were the hot item, that was probably mid to late 90s and it’s still going strong |
03-04-2018, 12:02 PM | #13 |
OK thanks for the help guys. I'm not too worried about performance since it won't be on the road all that often. I just want to keep the stock look because that's the look I prefer
03-04-2018, 02:58 PM | #14 |
I think the GM HEI is a nice reliable unit. The Chinese HEIs not so much. But it doesn't help him or me because we both want stock-bodied Delco style distributors.
Pertronix offers a ready-to-run Delco small cap distributor and I bought that for my truck, but on my current car restoration I'm using the module so I can keep the original date coded distributor.
