03-01-2011, 12:55 AM | #1 |
Suspension Questions
I have a thread started in the 67-72 section but have a few questions regarding the 88-98 trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=449977 Can I swap 1 ton spindles and brakes onto a 1/2 or 3/4 ton frame? Or am I better off buying a 3/4 or 1 ton frame to begin with? Thanks Guys -Nathan |
03-01-2011, 01:10 AM | #2 |
driving is in my blood
Re: Suspension Questions
Not sure about spindle swapping, but you can put HD 3/4ton/ LD 1ton [8700gvw] brake calipers on 1/2ton/LD 3/4ton rotors/spindles.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-01-2011, 01:12 AM | #3 |
03-01-2011, 07:21 AM | #4 |
One day...
Ya i went from 1 ton to half ton so its possible to go the other way too.
03-01-2011, 10:23 AM | #5 | |
http://www.duallyscene.com/forums/pr...ion-t4904.html
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-01-2011 at 10:26 AM. |
03-02-2011, 01:27 AM | #6 |
Thanks Guys, just what i was looking for, just wish he showed what all he had to swap from the donor truck, And that truck is pretty to boot.
03-02-2011, 02:01 PM | #7 | |
http://www.duallyscene.com/forums/su...lly-t4564.html
03-02-2011, 09:35 PM | #8 | |
