12-18-2009, 11:37 AM | #1 |
Differential ID help
Does anyone know what differential would be in a 2000 S10? I know it's a 4.10 ratio but I don't know the model. I have found literature that says up to 1997 they used a 7.5 or 7.625 ring gear diameter. Thanks.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
12-18-2009, 04:10 PM | #2 |
Re: Differential ID help
I believe it is the 8.5" 10 bolt
1972 C10 cheyenne super -350/th350 Wifes truck 1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc 2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear. 2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies. |
12-18-2009, 04:30 PM | #3 |
I thought it might be, but was not sure. Thanks for your help.
12-19-2009, 12:56 AM | #4 |
what engine do you have? if you have 4.10s, im guessing you have a 2.2. it would be a 7.625 then.
the 8.5 was used in zr2s and only a few reg s10s with the 4.3 |
12-19-2009, 11:56 AM | #5 |
Yeah, the 8.5 was kinda rare, mostly 5 speed 4.3's had them.
12-21-2009, 11:02 AM | #6 |
It's a 2.2L witt a 5 spd o/d.
12-30-2009, 04:12 PM | #7 |
It will be your standard 7 5/8 S10 rear probably. The 8.5 has a round cover on it, and the axle tubes get bigger right before they go into the pumpkin.
01-10-2010, 08:39 PM | #8 |
mines a 2000 and has the 8.625..think it may only be in ZR2's . A majority of the regular s10's will have the 8.5 if its a 99+ and has rear disc brakes.
stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
