Old 05-20-2012, 02:38 PM   #1
factoryorange3
factoryorange3's Avatar
Straight 6 250 sputtering after key is off
I have a 84 c10 with a 250 inline 6. Single barel carb. After truck is warm I shut the key off and the truck continues to sputter/pop for another 5-10 secconds. Anyone know what might be going on?? Thanks,Be njn
factoryorange3 is offline   Reply With Quote
Old 05-20-2012, 04:57 PM   #2
Wrenchbender Ret
Re: Straight 6 250 sputtering after key is off
Its usually caused by the idle speed to fast. Also can be from a vacuum leak. Some of those used a selinoid on the throttle to drop it back when you shut it down.
Wrenchbender Ret is offline   Reply With Quote
Old 05-20-2012, 10:40 PM   #3
68gmsee
Active Member
68gmsee's Avatar
After you check what Wrenchbender said also check the timing and choke adjustment.
If all checks ok, get a couple of cans of good gas treatment to put in the gas tank. You may have a build up of carbon in the heads and it may take 2-3 tanks full with additive added to clean out. Took me about three tries but haven't had a recurrence since.
68gmsee is offline   Reply With Quote
Old 05-20-2012, 11:47 PM   #4
Gumby
Gumby's Avatar
Has the truck always done this?
Or is this a new problem in recent weeks?
Is it a new problem after installing an elecric fan, radio....?
Gumby is offline   Reply With Quote
Old 05-21-2012, 04:00 PM   #5
factoryorange3
Recently. The head is rebuilt and it may be a timing issue as a result of truck being slammed off a curb due to a near missed car accident. Maybe distributor spun alittle.
