Old 12-05-2013, 03:27 PM   #1
DreamRyder1963
DreamRyder1963's Avatar
Getting Fuel to Carb
I am working on my brother's '69 GMC with a 305 V6. I can not get it to start but it tries to start with starting fluid so I am starting to think that it is not getting fuel. I by-passed the fuel filter to make sure that was not it. I also checked to make sure the sending unit was not clogged. How long should it take the fuel pump to get fuel to the carb?
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 12-05-2013, 04:22 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Getting Fuel to Carb
Less than 30 seconds. Pull the fuel line from the carb and put it in a quart bottle. See how long it takes to fill.
Are you getting spark?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 12-05-2013, 04:40 PM   #3
DreamRyder1963
Yeah I'm getting spark. It has a new distributor, cap, button, wires, and plugs. I'm trying to get the timing done but I can't do that since I can't get it started. This simple fix has been a pain in the a$$
Old 12-05-2013, 04:52 PM   #4
Longhorn 70
You should be able to get the timing kinda close while cranking as long as the battery lasts.
Old 12-05-2013, 05:57 PM   #5
cdowns
cdowns's Avatar
is this an hei or a points type distributor
Old 12-05-2013, 06:05 PM   #6
DreamRyder1963
Points Type. I have not found a HEI type that will work with this engine. I will try to time it as someone cranks it. I will probably try an electric fuel pump.
Old 12-05-2013, 06:21 PM   #7
DreamRyder1963
How much fuel psi does this engine need? 5-9psi?
Old 12-05-2013, 06:45 PM   #8
cdowns
cdowns's Avatar
set your points
Old 12-05-2013, 08:11 PM   #9
DreamRyder1963
The distributor came with pre set points but I will double check them tomorrow.
