10-09-2018, 10:52 PM | #1 |
O'Reilly's
Had need of a 25" 4 gauge battery cable and looked online. Napa had them but with the crappy spring ends. O'Reilly had them copper with the 'bolt' ends - so off to the store I went. It was folded up in a package about 6" long.
I couldn't hardly bend the old cable in a 90 much less 180. Course its China made. |
10-09-2018, 11:07 PM | #2 |
Re: O'Reilly's
10-11-2018, 07:56 AM | #3 |
Old member
Re: O'Reilly's
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-11-2018, 09:19 PM | #4 |
Re: O'Reilly's
Went by - they don't have 'post' cables.
10-12-2018, 09:11 AM | #5 |
Re: O'Reilly's
You can special order cables through a parts store from BWD-I have their catalog.
10-19-2018, 05:47 PM | #6 |
Re: O'Reilly's
Have you tried building your own? Its super easy if you use the solder pellets.
I've built cables for my suburban and my jeep using this method: https://www.wiringdepot.com/jt-t-tec...-Battery-Cable I put copper lugs on the end and use these terminals: https://www.wiringdepot.com/store/p/...als-clone.aspx This works especially well if you have a winch or dual batteries. I also replace the fusible link wire with a resettable breaker (still cleaning up the rest of that wiring): Last edited by ManNamedJed; 10-19-2018 at 05:53 PM. |
