06-19-2019, 09:21 AM | #1 |
Reassemble cab parts
I am now reassembling my cab interior.
Has anyone made a list of the order to put everything back in under dash ? Mine was total stripped before blasting and repaint . I know there’s an install order , I don’t want to do it more than once. |
06-19-2019, 09:41 AM | #2 |
Re: Reassemble cab parts
subscribed
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
06-19-2019, 11:21 AM | #3 |
landarts
I did this recently on my 72 Cheyenne that is a A.C. cab. There are some items that need to go in order or you are tearing it out again to get it right. Here is what I did from memory.
-brake pedal assembly -parking brake -windshield wiper motor -dash pad -items on dash like ignition, cig lighter -wiring harness -radio since it above the heater/AC controls -run any extra wires needed for speakers and or sub wiring -center AC outlet if you have AC -heater box assembly -AC/heater vent hoses - run them long out of the location they need to go -AC/Heater control panel -vacuum lines -door cabin switches in door jab if you have them -steering column - let hang down so you can attach oil line and plug in to dash bezel -dash bezel -glove box carboard inner -glove box door -kick panel vents -cabin light -install seats last it gives you room to work and have complete access to everything under the dash
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
06-19-2019, 07:17 PM | #4 | |
