08-16-2020, 12:15 PM | #1 |
R/F brake seized
A while back when driving,I noticed smoke coming from the R/F corner of my 87 Suburban. Once I stopped I noticed the R/F wheel area was very hot. I figured the Caliper was seized. I bought new calipers, rotors, and bearings. After we replaced all of that once we bled the brakes the R/F was still seized up. I have heard that the rubber hoses can come apart inside and not let the fluid flow back and cause the caliper to stick. It looks like my hoses are original/very old. Should I suspect this is my problem?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
08-16-2020, 01:17 PM | #2 |
Re: R/F brake seized
Most likely. My daughters 2005 had that problem so not crazy to think you might.Hydraulics will push the fluid through but it can't return so the caliper will lock. Just turn the bleed screw and it should release and then lock again.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-16-2020, 02:52 PM | #3 |
Thank you for confirming what I was thinking. I already have some new hoses. Just need to find time to replace them. Thanks again.
08-16-2020, 06:27 PM | #4 |
Just here to tinker
You're on the right track. It is most likely the hoses. I am about to replace mine as well.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
