What exhaust are you guys running with your swap?
Obviously nothing is going to bolt right up after the swap....but Im curious what system you guys started with and then modified. Im thinking about running the pipes so that they dump out the side right in front of the rear wheels. I may just buy some Thrush glass packs and one of Summit Racing's build it yourself 2.5" exhaust kits. Im running the hooker cast LS swap manifolds to clear my CPP tubular motor mounts and the factory column shift linkage.
Old member
I plan to let 3rd gen do mine and dump under the truck at the rear axle. Right now he is just going to tie into the 2.5" that is there now. My ultimate goal is for S/S once I get it running.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Boosted Member
Re: What exhaust are you guys running with your swap?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
hahaha, thats awesome
DT headers to cut-outs, 2.5" x-pipe to Hooker aerochambers over the axle and straight out the back. Just got it back from the shop today! I'll post a link to a video tomorrow. Used to run Flowmasters on my 350/NP435, but it was too loud for a daily. Probably would have worked better now that I have overdrive, but my brother is using them with his buick.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Fabricate till you "puke"
Hooker street rod shorties/stainless mandrel bent downs(speedway motors). The system goes 2 1/2" pipe, front to rear/H pipe/ 50's flows....exit through the rear bumper....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Hi flynavy30, I remember all the negative specs on glass packs, excessive backpressure, tone quickly changes to a bad loud note when the fiberglass burns/blows out. A friend put those behind a sbc in a chevelle and in 3 weeks hated them. I'm kinda old school and in the 60's-70's corvair turbo mufflers were the rage and i still like a 2 1/2" inlet/ 2 1/2" outlet staggered, short body, (not straight through). Nice tone but not obnoxious. There is new mufflers out now that i would consider when the time comes, Corsa, Borla, etc, that have the drone toned down. Not trying to rain on anyone's parade, but ask around. Sound bites are on some websites also and seem legit. Good luck, Brian F.
Right now I have 99 Fbody manifolds, 2.5" straight piped to thrush turbo mufflers. Sounds great. The manifolds will soon be flipped and connected to a 76mm Turbo and who knows from there.
Truck and auto performance nut
Mine's running Dynatech F-body swap headers, a dual 3" Flowmaster build your own exhaust system with Summit turbo mufflers...dumped at the rear axle. Its amazingly quiet at cruise but give it some pedal and it starts sounding like its running open headers.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Hooker block hugger shorties, 2.5 pipes through Thrush Welded mufflers. I am VERY pleased with how these mufflers sound, and they are half the price of Flowmaster, which I have run with the last two motors, so I'm not talkin trash, just wanted something a little different.
my big hurdle right now it trying to determine if the Holley manifolds will in fact clear the CPP motor mounts.....
If you are running an auto trans, I think you will be ok on the hooker cast manifolds? Where the fit issue comes in, is if you run a gen I stick shift....most headers, manifolds will not clear the clutch linkage. Best of fun,Longhorn
Thanks longhorn, I figured Ill be ok with the shift linkage, its more clearing these CPP motor mounts Im having difficulty with....didnt realize they were such an issue
Can you shoot a couple pics of what you are dealing with? Longhorn
#15 |
I used eBay stainless shorty headers for 2nd gen Camaro ls swaps, into 2.5" dual exhaust, with x-pipe that was custom fitted & welded by me. For mufflers I used 2 magnaflow stainless 24" long mufflers with turndowns in front of the rear axle. Real quiet at lower RPM's but sounds mean at 5K
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#16 |
#17 |
I think I missed something in the 'mix'...I thought that you were running Hooker cast iron headers? The back side of those stands , do look to be intrusive, for anything that you would mount for headers tho... Longhorn
#18 |
I ordered the Hooker manifolds to see if they'll work since I couldnt find anyone who could definitively say they do or do not work with the CPP mounts....still waiting for them to arrive
#19 |
My thoughts are, that you wont really know, till you set the engine into place? At that point, you might be able to opt for different engine mount plates (for the block), if the fit is too tight. Best of fun....let us know how she goes, Longhorn
#20 |
![]() Join Date: Sep 2005
Trailblazer ss manifolds are what i is running
#21 |
What mounts/stands are you running? It has been showed here, that you can go a dozen different ways , on the setup.....too bad that nobody sells a complete kit
#22 |
thanks Longhorn, Ill keep you up to date....Im leaning towards the Thorley headers, despite the expense as I think the plumbing of the remainder of the exhaust will be easier with the longtubes....we'll see. I may still try to fit the manifolds and see what the clearance is, Ill keep you updated!
#23 |
![]() Join Date: Jun 2012
I am using the Trailblazer SS manifolds with Borla Pro XL mufflers.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#24 | |
#25 |
Open hooker ls swap manifolds, its loud. Like gravedigger loud.
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
