Old 12-13-2015, 10:34 PM   #1
67chevysupercharged
67chevysupercharged's Avatar
Questions about Duramax
Hi all, right now I'm looking at possible buying a 2001 RCSB 1/2 ton that's had an 05 LLY/Allison swapped in that has an injector hold down hole that is stripped out. Wondering if anyone has any experience with a similar repair, and what did you use, helicoil or timesert? Also, for those that have owned or own a Duramax, how is maintenance and repairs on a Duramax? I have an idea on prices on general things like injectors, but are there any other common repairs?
Thanks,
Zak
71 Longhorn 402, PS, PDB, AC, Tach, Posi
67 SWB 6.0 LSX swap, 4/6 ECE Drop (Work in Progress)
2002 Victory Red ECSB Silverado 5.3 (DD)
67chevysupercharged is offline   Reply With Quote
Old 12-14-2015, 12:53 PM   #2
usetheBFH
usetheBFH's Avatar
Re: Questions about Duramax
A helicoil would hold if you keep the engine at stock levels. I would do a time-sert and not worry about it.
1970 C/10 | Short Bed | 2wd | 12-Valve Cummins 6BT | 47RH Auto
Instagram | usetheBFH
Coal Chute http://c10forum.com/forum/showthread.php?t=19671http://
usetheBFH is offline   Reply With Quote
Old 12-15-2015, 03:25 AM   #3
67chevysupercharged
Hey thanks for the reply, I wasn't sure if a time-sert would be strong enough, but if it'll work I'll use that if I get the truck. But are there any common problems with the LLY platform I should look for specifically on this truck?
Thanks,
Zak
Old 12-15-2015, 09:56 AM   #4
4x4toy
Timesert is GMs approved repair. May even have a fixture online to repair it.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 01-14-2016, 07:54 PM   #5
zeldman
zeldman's Avatar
I have a 2005 Duramax that just hit 100K miles. I have had zero problems with it.
I let it sit for 4 months over last summer as I worked in Alaska. I left a battery maintainer on it and when I got home it fired right up.
As far as repairs, the most common seem to be water pump replacement around 200K.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
