02-27-2020, 07:37 PM | #1 |
High build primer
So i I think I'm ready for 2k primer. What I've done is media blasted then epoxy coated then body filled then I used glazing putty ,blocked it all. My question is when I block sand and use guild coat on the 2k do I respray the low spots? Assuming I will get down to the body filler on both sides of the low spot. Or do I add filler?
02-27-2020, 08:14 PM | #2 |
Re: High build primer
Depends on how low the low spots are...what type of glazing are you using?.....on mine I sprayed epoxy over my filler work then sprayed the high build...if it was really close I'd use evercoat metal glaze on mine...but only thin coats..
02-27-2020, 09:51 PM | #3 |
Ya good point I figured I would respray the bare spots . I think it's pretty flat but I guess I will know when I start sanding . So you added more filler in the lowes?
02-27-2020, 09:56 PM | #4 |
Yeah , I just skimmed the lows..but its important to get the panel as flat as possible before you ever start filling..
02-27-2020, 10:03 PM | #5 |
The proper steps are as follows:
1. hammer and dolly/welding/grinding - metal work in other words 2. epoxy primer 3. body filler 4. finishing putty 5. 2K high build primer 6. paint Think of it this way; heavy coarse work first, then epoxy primer for corrosion resistance, then work your way up through finer and finer products until you get to paint. Perhaps nsb has a better way of doing it?
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
02-28-2020, 09:42 AM | #6 |
LMAO AKA the hack
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
