Old 10-08-2009, 08:21 PM   #1
nac593
how to do a burnout?
Isn't there a certain technique to doing a burnout?
nac593 is offline   Reply With Quote
Old 10-08-2009, 08:28 PM   #2
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Re: how to do a burnout?
Yes there is!
1.) Start the truck
2.) Put it in drive or 1st gear
3.) Stomp on the pedal furthest to the right
4.) Don't wreck
Honestly, theres nothing to think about, just get on it.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 10-08-2009, 08:32 PM   #3
nac593
I thought you use the brake a little?
Old 10-08-2009, 08:34 PM   #4
ts71281
If you need to use the brake, you don't have enough power. Real cars/trucks don't need to apply the brakes to do a decent burnout.
ts71281 is offline   Reply With Quote
Old 10-08-2009, 08:35 PM   #5
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Originally Posted by ts71281 View Post
if you need to use the brake, you don't have enough power. Real cars/trucks don't need to apply the brakes to do a decent burnout.
werd
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 10-08-2009, 08:39 PM   #6
nac593
I put in a 290hp crate motor. not enough?
Old 10-08-2009, 08:45 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
it's a good start!
if you do use the brake, just use enough to keep the truck from rolling, and you don't have to rev the piss out of it to keep it spinning once it starts, your motor will thank you. 3-4k rpm should do it.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-08-2009, 08:46 PM   #8
mclairmo
Back of trucks have no weight over them, should be easy to burnout with 290 hp and a heavy enough foot.
mclairmo is offline   Reply With Quote
Old 10-08-2009, 08:56 PM   #9
UltraBlue71
UltraBlue71's Avatar
Mine aways wants to hop, weird how some trucks really hook and some want to bounce, mines a manual tho, pozi too, maybe shes just a pooch....
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 10-08-2009, 08:59 PM   #10
texanidiot25
Eat My Rust
texanidiot25's Avatar
Left foot lightly on brake, right foot to the floor, and let'er roll out! Just use the brake to keep the truck rolling steady. Rollin' burnouts > Brake stands.
texanidiot25 is offline   Reply With Quote
Old 10-09-2009, 03:40 PM   #11
americanmusc1e
americanmusc1e's Avatar
I'm guessing you have a leaf-spring rear end???
'cause the trailing arms on a coil-spring truck don't usually hop, leaves will almost always hop.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 10-09-2009, 03:47 PM   #12
texanidiot25
Eat My Rust
2nd gear posi burnouts across parking lots can attest to this!
Old 10-09-2009, 04:46 PM   #13
84_4x4
84_4x4's Avatar
i dont see why your having a problem i have a fairly stock 350 and can spin 2nd from a roll is your clutch any good
1971 c10 350ci long bed fleet side
84_4x4 is offline   Reply With Quote
Old 10-08-2009, 09:00 PM   #14
tcb-1
Nothing to see here.....
tcb-1's Avatar
two words..... line lock
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-08-2009, 09:12 PM   #15
surfacerust
well, i hold the brake to get em started rolling up to about 3500 rpm then let off the brake give it 2nd and mash it on down!
surfacerust is offline   Reply With Quote
Old 10-08-2009, 10:44 PM   #16
AusTx68
AusTx68's Avatar
two words...big block
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 10-08-2009, 09:03 PM   #17
texanidiot25
Eat My Rust
Even my ol' V6 Firebird and mom's Jimmy could light up easy.
Old 10-08-2009, 09:05 PM   #18
nac593
Am I supposed to be in 1st gear?
Old 10-08-2009, 09:07 PM   #19
texanidiot25
Eat My Rust
Yes, otherwise it will try and upshift. Unless you have the power the burn out will end. Just keep your RPMs in check.
Old 10-08-2009, 09:15 PM   #20
cdowns
cdowns's Avatar
the best pavement for doing a burnout is directly in front of the police station
Old 10-08-2009, 09:16 PM   #21
texanidiot25
Eat My Rust
OR a cops house... Little did I know he was my friend's neighbor...
Old 10-08-2009, 09:20 PM   #22
nac593
Is this no big deal or am I really putting a lot of strain on the truck. It has all new parts.
Old 10-08-2009, 10:01 PM   #23
texanidiot25
Eat My Rust
The only time you strain anything is when breaking the tires loose, once their free it's like freewheelin' on a slick road.
Old 10-14-2009, 10:31 PM   #24
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If its an automatic & you push on the brakes too hard it can make the trans slip
It wears out your brake shoes
And if you have an open rear end, you will wear it out pre-maturely, or sling the spider gears out of it if you spin one tire too fast
You can over rev your engine if you dont have a tach or are not paying attention
And last but not least, its addicting & you tend to use tires up faster than normal
No, its not the best thing, but its fun
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-14-2009, 10:40 PM   #25
brad_man_72
the boat guy
brad_man_72's Avatar
if a 15 year old kid cand do it in a ford, c-mon now.
the shop i work at made the driveshaft kid went though 3 sets of tires in 3 days.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
