Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-06-2008, 02:29 AM   #1
1970chevy
oil accumulator
Is any body running a oil accumulator on a bbc i just pick on up and wondering were i should tie it in i was looking at the oil press line that comes off by the filter
1970chevy is offline   Reply With Quote
Old 04-06-2008, 05:19 AM   #2
powerbench
powerbench's Avatar
Re: oil accumulator
ya we have one, have it plumbed into the lower portion of the block.I removed one of the plugs , right near the front of the block. sorry i don't think i have any pics..
powerbench is offline   Reply With Quote
Old 04-06-2008, 07:50 PM   #3
regan wilson
regan wilson's Avatar
Re: oil accumulator
I use one its a 1 1/2 qt . Its plumbed in above the oil filter . I just had a line made and used a fitting that I could tap off of for my oil press guage . I would recommend a 3 qt one though . I broke a stock oil pump one time and lost the rod bearings and bent the crank . An extra 1 1/2 qts would have saved it .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 04-06-2008, 09:35 PM   #4
1970chevy
Re: oil accumulator
do u leave it on all the time or only on start up
Old 04-06-2008, 09:50 PM   #5
regan wilson
Re: oil accumulator
They tell you not to but I do . I do have a Titan pump and run synthetic oil though . Just baby it when you start it like you should anyway .
Old 04-07-2008, 05:01 AM   #6
1970chevy
Re: oil accumulator
thanks now i was reading and it said to put 2 quart in accumulator do u run 6 quart in motor and 2 in accumulator or run 4 quart in motor and 2 in accumulator
Old 04-08-2008, 05:23 PM   #7
regan wilson
Re: oil accumulator
The accumulator is (extra oil)....You will have to add 2qts to your normal oil capacity .
Old 04-09-2008, 03:24 AM   #8
1970chevy
Re: oil accumulator
thanks
