11-14-2007, 05:52 PM | #1 |
front coilovers
I havent posted on this forum for a long time but I figured some people might be interested in my latest project. Im installing adjustable coilovers in the front end of my 67 SWB. The coilovers are both heigth and dampening adjustable and theres a wide variety of spring rates. Anyway heres some progress pics:
11-15-2007, 10:48 AM | #2 |
Epoxy Primer Friendly
Re: front coilovers
nice, who made the brackets?
11-15-2007, 12:09 PM | #3 |
A guy with a truck
Re: front coilovers
Very nice. Could even use these for Shockwaves...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-15-2007, 02:53 PM | #4 |
Too many projects
Re: front coilovers
That'll get her done. Nice fab work, looking forward to see it bolted together and the stance you set.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
11-15-2007, 07:03 PM | #5 |
fuel
Re: front coilovers
this would be a nice kit, are you going to offer it or is it already offered??
72 w/67 front clip 415ci fuel injection t56 air ride 18/20's |
11-15-2007, 08:06 PM | #6 |
Yellow truck club
Re: front coilovers
Neat work.
I'm assuming the camera is not set for the correct date or else you did this five years ago and just got around to posting them Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
11-16-2007, 05:12 AM | #7 | |||
Re: front coilovers
Thanks for all the encouraging comments and Ill post more pics as the work gets done. |
11-16-2007, 01:46 PM | #8 |
Re: front coilovers
Very cool & a nice alternative. Post up pics once it's all installed so we can see ride height & give us your 'seat-of-the-pants' opinion (even though it might be a little biased ).
12-25-2007, 02:44 PM | #9 | |
"GOD BLESS AMERICA !!!"
Re: front coilovers
I'm looking to build a set myself. That's how I found this thread, I was looking at what was available and what other were doing. I want to add at least 3" of lift and have my uppers adjustable so I can correct the rake and caster. I would love to get the Auto_CAD drawings in a pdf. file or have it burned on to a CD !?!?! |
11-16-2007, 06:42 PM | #10 |
Re: front coilovers
Were did you get thoes A-arms?
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
11-17-2007, 05:44 AM | #11 | |
Re: front coilovers
12-24-2007, 12:49 AM | #12 |
Re: front coilovers
I got the lower arms mocked up so I figured Id post some more pics. I hope to get the arms gusseted and finish welded this weekend. The pics are in full droop and nearly full compression.
12-24-2007, 08:40 AM | #13 |
A guy with a truck
Re: front coilovers
Nice! She's gonna be loooowww, eh?
12-24-2007, 04:33 PM | #14 | |
Re: front coilovers
01-02-2008, 09:21 AM | #15 |
Re: front coilovers
In case you have not seen any of the posts I have made recently... I'm going in the "opposite" direction everyone here is going.. I'm building our C10 with a '60's gasser look... .... so I'm looking for a way to "raise" the frontend rather than drop it. It would be nice to have the frontend adjustable from where it is now (3" drop) to ???" .... whatever it takes to get that bad-ass gasser stance. Looks like a coil-over setup like this would work for me???? What ya think???? Thanks ....
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? |
01-21-2008, 12:14 PM | #16 | |
Insert Title Here
Re: front coilovers
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
01-21-2008, 03:34 PM | #17 |
Re: front coilovers
The biggest problem with raising the front of the truck is going to be the ball joint and tie rod angle. I say straight axle, just keep it simple.
01-21-2008, 06:06 PM | #18 |
Re: front coilovers
The more I keep digging into the alternatives of using a straight front axle the more I keep ending up "back" to my original plans to use one.
Initially I thought using "taller" springs or a "coil over" setup would accomplish the same task as the straight axle but without it's "historical" problems. Then more & more people I have talked to and chatted with on this forum they have helped me remember a "few things" I have over-looked in my "dream list" planning. Any (& all) suspension mods come with their own set of problems. Whether it be to "lower" or to "raise" a suspension .... especially when you're talking about "significant" alterations like a "gasser stance" would be. Sure I could use an "adjustable setup" or "airbags" for raising the front end to the "gasser height" but then one look underneath the truck and the other "important" part of "customizing" any vehicle to a "vintage look" like the one I want is gone..... how it looks.... . There is NO doubt the "straight axle" setup not only gets the job done but also has the "look" that shouts "hot rod". Another thing that was also mentioned here was back when (aka.. "in the day") many of us who were either using a staright front axle or "any" other suspension setup (front or rear) very often we did it with "limited funds" and/or used parts just to "git 'er done". Nowadays we have more "hot rod smarts" and tons or "new parts" and custom parts (along with a few more bucks) than we did when we drove our "rods" to the high school dance on Saturday night.... and on Sunday morning put on the "slicks" and up-capped the exhaust cutouts at the drag strip (with some street racing in between ) So I am going to keep looking into a "straight axle" setup as my first plan. The "World of Wheels" custom car show is in a few weeks here in Pittsburgh and I know of a few "street machines" that are using a straight axle setup that will be there. No doubt my camera will be ready and I'll be spending time talking with rodders who have done this already. More about this as time goes on..... 10 degrees outside with the wind howling.... still gots "lots" of Winter ahead... ; > ( And like "many" others on this forum I also have LOTS of work to do before I have to decide on what to do with the front suspension.... chopping the roof 5 inches - roll cage - fitting the one piece fiberglass "tilt" front end and making a "fiberglass bumper/rollpan" (???? that could be FUN!!!) - replacing the engine with a "383 stroker" just for "starters"....ha!!! Thanks again for the words of advice & encouragment .... John
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? Last edited by PA-IndianRider; 01-21-2008 at 06:09 PM. |
01-24-2008, 07:13 PM | #19 |
Re: front coilovers
Heres the latest progress, lower arms are welded, gusseted and painted. I hope to get them installed this weekend but you know how that goes. Anyways, heres the pics.
01-24-2008, 11:09 PM | #20 |
Re: front coilovers
What coil overs are you using (size, P/N, ect)? I'm looking to do something similiar, I'm not so much worried about going that low, but I like the adjustability and I want to relocate my shocks anyway. Thanks
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
01-24-2008, 11:50 PM | #21 |
Re: front coilovers
Those look great! I can't wait to hear how it handles!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
01-26-2008, 12:26 AM | #22 |
Re: front coilovers
Is it worth going to a coilover setup on a stock ride height truck? I like the stock look but the handling in my truck leaves alot to be desired. I'm not looking for Indy car handling just an improvement(less body roll and not having to slow to 10mph to take a turn). I already have a front sway bar but everything else is stock. I get spoiled driving my late model charger but I love driving my truck too.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
01-30-2008, 02:45 PM | #23 |
Re: front coilovers
Well, good news and bad news. Good new is that i got it all installed and it all fits well. Bad news is that the the springs are nowhere near stiff enough. When I lowered the jack down for the first time the truck was resting solid on the jack, I then put blocks under the tires and found that the coils were in total coil bind. Needless to say I need a much heavier spring so i ordered a set of longer and heavier Eibach springs from summit.
Anyhow heres some pics. |
01-31-2008, 11:12 AM | #24 |
Re: front coilovers
I hate to ask again, but can you identify what componets you used for your coil overs? What are the P/N? Thanks
01-31-2008, 06:45 PM | #25 | |
Re: front coilovers
