Old 11-07-2008, 11:10 PM   #1
TheQuicksilver
1953 Chevy 3100 Project
Time to break myself in on the forums and make this post #1. I closed the deal today on my "new" truck, a 1953 Chevy 3100 (for those interested, it cost me a cool $3000). It's running, and has been converted to 12V and had an engine swap out to a 261 with a 235 head at some point in the past. The same guy has owned it for the past 37 years (he paid $125 for it in 1971).
My immediate (as in tomorrow) goals to address are the three on the tree shifter, which seems to have something binding the linkage preventing it from going into neutral, 2nd, or reverse (thoughts, suggestions, or advice welcomed). No gear grinding or anything, the shifter just don't wanna go there. The other is I want to hit some of the surface rust with some sandpaper and seal it with primer.
Long term, she'll get painted back to a rich, dark green. New tires and hubcaps, a new wood bed with some wood side highteners (is that even a word?). New furniture most of the way around (handles, trim, etc). Going to update the interior just a little with better insulation and upholstery, even considering bucket seats, though that might be a bit too far from stock for me. I'll also probably install power steering at some point, on consider updating the transmission to something more highway friendly.
My ultimate goal is to have a good, daily driver truck. Not a show truck, not a hotrod.
I have a Flickr set with plenty of initial photos that I'll be keeping up at http://www.flickr.com/photos/fienen/...7608722892176/
Here's some to show it off:
TheQuicksilver is offline   Reply With Quote
Old 11-07-2008, 11:19 PM   #2
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: 1953 Chevy 3100 Project
Welcome aboard.... love the "Bill"... nice truck
Kenny
87Lowrider is offline   Reply With Quote
Old 11-07-2008, 11:19 PM   #3
Kid
Kid's Avatar
welcome to the board from Wellington. Looks like you have a VERY clean unmolested truck there. What a bargin!!
Kid is offline   Reply With Quote
Old 11-07-2008, 11:19 PM   #4
Albatrossian
Georgia Boy
Albatrossian's Avatar
Sweet truck and welcome to the boards from GA!
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 11-08-2008, 01:51 AM   #5
dan42
dan42's Avatar
Nice truck - that was a good deal. I like 'em close to stock as well - good luck on it, and keep us posted.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-08-2008, 09:11 AM   #6
Lextech
Lextech's Avatar
Wow, Very clean starter project. That was a great price for such a clean truck.
Jeff
Lextech is offline   Reply With Quote
Old 11-08-2008, 11:25 AM   #7
Kim57
Kim57's Avatar
Looks like a nice truck.
Kim
Kim57 is offline   Reply With Quote
Old 11-08-2008, 04:50 PM   #8
OrrieG
OrrieG's Avatar
Hello - looks like a good start. $150 in '71?? Guess I paid to much for my 59 in 76, it was $375.
Old 11-08-2008, 06:08 PM   #9
TheQuicksilver
Well, I appear to have proven good at two things, taking stuff apart, and putting it back together and making the problem worse. I tore into the problem shifting this morning. Turns out I was wrong, it's just flat out stuck in third. The linkage isn't the problem, as I was able to disconnect it and move things fine. I pulled the side off the transmission, moved the interconnects around fine, shot some gear oil into the crank case, and sealed it back up (nothing looked wrong inside the tranny, but I couldn't see well). Anyway, started it back up, and now not only will it not shift out of third, the truck won't actually even move. Before, it was in third, and would at least go forward when I let off the clutch, now, it just dies. So either I screwed something up bad, or the gears aren't set up the way they were before. Either way, it's going to be a long week. Blegh.
Old 11-08-2008, 06:26 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
what happens on these covers is the pin at number 1 wears on the recesses in number 2. that makes it easy for 2 gears at one time. Number 3 get turned around when putting it back and that locks it up also. Thew linkage is also a problem combined with the cover wear you have consistant lockups that require you crawl under and move the levers back.
Old 11-08-2008, 09:02 PM   #11
TheQuicksilver
Originally Posted by dwcsr View Post
...that makes it easy for 2 gears at one time...
You mean it's easy to engage two gears at one time? I'm going to pull it back off tomorrow and double check the direction of the keeper you noted at #3.
Old 11-08-2008, 11:04 PM   #12
Daniel U
Daniel U's Avatar
Nice truck! I saw someone on here do a T-5 swap with little or no fab work. I think there was a different trans. cross member and a new shifter, but his was a floor shift to begin with.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 11-17-2008, 04:55 PM   #13
TheQuicksilver
Got started with some sanding and initial priming to stabilize some rust this weekend. Pics coming. This thing must have been at least four different colors over its life. I think I'm gonna need a better sander to blow through this.
Also got it out and drove it around town some. She actually cruises VERY nice. Got it shifting good, accept for some resistance going from 2nd to 3rd, where it likes to grind. Heater works good. Planning an order into classicparts.com this week for some misc. stuff, as well as new tie-rod ends after I take a second look underneath. When I was under it working on the tranny, the tie rod setup didn't look at all like what the catalog shows. Not sure what that's all about just yet.
Old 11-17-2008, 07:48 PM   #14
55dude
55dude's Avatar
t-5 swap requires rearend swap also, open driveline. a 55'-59' TF will bolt into your AD to make conversion. check out www.stovebolt.com for swap info. nice truck!
55dude is offline   Reply With Quote
Old 11-17-2008, 07:58 PM   #15
nuke1
nuke1's Avatar
welcome from saskatchewan canada and nice truck you have there, great starting point.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-17-2008, 10:06 PM   #16
TheQuicksilver
Here's a picture, as promised:
Re: tranny swap, the more I think about it, the less I want to do it, if only because I'm a sucker for keeping things as original as I can, and getting rid of the three on the tree seems like a damn shame.
Old 09-05-2011, 10:42 PM   #17
jocko
jocko's Avatar
While I understand the desire to keep something all original - especially considering you're starting with a 3onthetree - one can easily swap the T5 in and use a floor shifter that is "disguised" as an old granny 4.
Here's a thread on doing it on a 60-66 (but you will have different considerations, as mentioned above, a rearend swap required also.
http://67-72chevytrucks.com/vboard/s....php?p=4879486 it might highlight some of the considerations.
I am done for now - but future plans call for an old black stick and doorknob (or original 66 4-speed knob), and maybe, just maybe, a 5-speed patter etched or scribbled onto it.... http://prostores3.carrierzone.com/se...obs/Categories
Old 09-05-2011, 11:03 PM   #18
TheQuicksilver
At this point, my main goal is to finish it out as is, drive it around with a for sale sign in it, then "upgrade" to a slightly older but already restomodded truck (old body sitting on modern powertrain). I'm a smart guy, but the only way I could pull off that kind of conversion is to write a check for it, and I just don't think it's worth it for me in this case for this truck.
Old 11-17-2008, 10:20 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Welcome to the board from Mid-MO!!!
Great looking '53!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-18-2008, 08:11 PM   #20
TheQuicksilver
Got my next mystery. I'm looking to replace my tie rod ends in the front end, because the steering has a mean wobble to it. Something about the whole assembly doesn't look quite right though. First off, the steering assembly doesn't look like a 53 setup. If anything, it looks more like one from a 55+. Secondly, it looks like the tie rod sits REALLY low to the ground, though that might be because they don't have the right size tire on the truck. Here's some pics I took today to show it:
http://flickr.com/photos/fienen/arch...ed/2008/11/18/
What do you think? Honestly, I don't think it quite matches either, the control arms the tie rod ends hook into don't really match the 47-55 or the 55+. Has it maybe been replaced at some point with some aftermarket setup?
Unrelated; in the last picture, that's on the passenger's side of the engine. The pipe coming off it appears to just go down and sits open at the bottom, not connected to anything. What is that?
Old 11-18-2008, 08:41 PM   #21
54 jimmy
54 jimmy's Avatar
that tube is called the road draft tube it is the crank case breather. road draft tube is a very primative valve cover breather. you'll probably notice that the undercarrige of your truck is a greasey mess that is from the road draft tube.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 07-06-2009, 10:58 AM   #22
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
Nice truck. Any updates beside looking for tires?
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 07-06-2009, 09:03 PM   #23
TheQuicksilver
You caught me. I was just thinking about how bad I'd been about any new news since posting about the tires, heh. So YES, here's some stuff to chew on.
First, just got the radiator back from being resoldered for a couple leaks. Replaced all the hose while I was at it. Started it up, ten minutes later I was sitting at 212 degrees and no apparent coolant circulating. I think the thermostat might have frozen up while it was dry and stuck closed, so I'm gonna replace that this week and retry.
Had an appointment to get kingpins redone, only to be blessed by a master cylinder bleedout before I could get it up to the shop. Luckily, I knew there was a leak, so I have a rebuild kit already (just hoped it'd wait long enough to let me get the pins replaced before giving up), but I'll have to pull all the carpet out, which isn't original, and I think is glued in before I can get at it. On the plus side, I just bought a brand new jack, so I might be able to get at it from underneath maybe.
Pulled the fresh air vent free and cleaned out all the caulking they'd sealed it with. Gonna pull the vent out to put in a new molded gasket and replace a missing bolt in the control arm so it pulls it down all the way.
Other news (pics below, and has anyone else noticed the Flickr embedding in the forum seems all kinds of screwy?): Front bumper re-whited (rear following shortly), bumper brackets blacket, front splash panel behind the bumper pulled to get some bondo to smooth out some dimples in it, new door panels installed with new window cranks and door pulls, new horn push, new headliner.
Full Flickr Gallery
Old 07-09-2009, 10:20 PM   #24
TheQuicksilver
Got the master cylinder refilled tonight, and have brakes again. Also replaced the thermostat. Couldn't do a test drive tonight, as the battery was dead, so I've got it on to trickle charge overnight and will warm her up tomorrow. If all goes well, now kingpins soon! (assuming the cylinder 4 misfire code I'm getting on my car doesn't drain my funds getting fixed.)
Old 07-18-2009, 07:22 PM   #25
TheQuicksilver
Started work refinishing the rear bumper, replaced all the plugs and ignition coil. Also did a color test on the fender with the new green.
Also bought carpet to use in the cab to replace the old worn out, ugly green crap:
