What is your engine setup?
Just for kicks what is your engine setup? What size, carb, intake, heads, cam, headers etc. What would you chang if you could?
Brad 72 Blazer CST 350/350/205 ![]() ![]() |
Re: What is your engine setup?
It's in the sig.
I'd have a 383, and a roller cam. |
ENGINE BUILDER
383 STROKER, 272H cam, 202 heads, HOLLEY 600, headers, HEI,change??? NOTHING!!!!
JIM ZAG |
![]() Join Date: Jan 2008
406, VICTOR JR.HEADS, JESEL SHAFT ROCKERS,COMP 286 XTREME ROLLER,SPLAYED MAIN CAPS,CRANK SCRAPER AND WINDAGE TRAY,BOWTIE SINGLE PLANE W/REWORKED 750 HOLLEY TO 830,AND PRO SHOT FOGGER. NO CHANGES!
406, aluminum heads fully worked, eagle crank, je pistons, worked hp650, victor jr intake, doug thorley headers, roller cam, msd billet dist, msd ignition, taylor 8mm wires there is alot more just cant remember all off the top of my head,, is it fast ??? of yes
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
WOW those are some serious engines I just have a little stock 350 with and Edelbrock 700 and performer intake. I want heads and a mild cam soon though.
Tot Roddin'
Well...
I6 250 (bone stock)
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
"THE GREEN GOBLIN"
454BB msd billet dist,msd 8.5mm wires, 750 cfm 4-Barrel Proform Race Series Carburetor,FlowTech Full-Length Ceramic Coated Headers,Meziere Enterprise Electric Water Pump,Holley Blue Electric Fuel Pump to help feed it. Weiand Intake Manifold, Heads well I know knothing about the heads But I would like fully worked aluminum heads in the future. My Cam thats another I know nothing about yet but it sure sounds good..
Change I would like a fully Blown 572 ![]()
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Junior Member
You guys realy have some nice modified engines.
I have a bone stock 350 in my '71 C-10 lwb stepper and a bone stock 250 in my '67 swb stepper. What would I change, I guess clean them up and paint them original colors. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Another stock 350 here with a Q-jet sitting on an Edelbrock 2101 (stock intake cracked).
About the only things I wish I had done differently would be spend the extra $$ for a 383, and figure out why the vacuum is so low (maybe brake booster?) so I could use my big cam and still have it start & idle when cold.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Gearhead
I just have a stock 96' LT1 w/bolt-ons
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
motor exploder
454 (+.040), Holley spreadbore (650?), stock intake, peanut port heads , RV cam, stock manifolds
here's what I'm changing to- the parts are sitting here waiting for me to install! ![]() Holley 870 carb, E'Brock RPM-O Air Gap intake, E'brock RPM-O Aluminum heads (2.25/1.89 valves), Comp Cams 278 Xtreme Energy Cam & Roller Rockers, Hedman Ceramic Coated long tube headers.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Stock low miles 1989 Roller cam 4bolt 350 shortblock with comp 276 roller cam, unknown history double hump 61cc 2.02 intake old school fully ported heads, full length Headman headers, 2800 stall TCI converter, Painless Delphi based EFI with F&B 6barrel MPI intake. Walbro 255lph fuel pump, Mallory regulator and Fram Fuel filter. 275rwtq, 265rwhp, both at 5000rpm (limited)...Still new to building Chevrolet motors, so Im here to learn!
Bruce |
Devil's in the Details
'88 TBI 454 from a C3500. Stock rebuild aside from the Edelbrock Performer intake, Doug's headers and cam upgrade. Stock computer and everything transplanted into a 1970 Suburban. I'm hoping to fire it up for the first time here in a few weeks. Nothing super spectacular, but I'm looking for 450+ ftlbs of torque down low in the rev range to move the heavy thing (wish I had the moolah for some 60499 heads).
The other is a .030 over 350 w/ Edelbrock aluminum intake, q-jet, RV cam, HEI, Doug's headers and 2.5" dual exhaust w/ Flowmasters. I like it because its loud. ![]()
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle Last edited by Beelzeburb; 06-11-2009 at 12:04 PM. |
#15 |
455 Buick, waiting to be massaged and shoe horned in.
#16 |
English Chevy Owner
Mine is supposedly a 300hp 350 from a camaro, running the numbers does seem to support this, truck had a six in it when it left the factory. I'm pretty sure the cam isn't stock, but I don't know what it is, stock intake with a newish Carter AFB four barrel, carter electric fuel pump to match K&N, and a Mallory twin point dizzy. The dizzy and manifold are going to be replaced with an Performer EPS and a stock (used) HEI again from a camaro that I have sitting in the garage waiting to go on. Ramshorns and 2 1/4" duals finishing in front of the rear wheels.
The guys from a local garage that specialises in US trucks and a friend who drag races a 9 second camaro reckon it is pretty quick for a big lump of a truck. I'm hoping the manifold and HEI will perk it up a bit along with a good tune up. Still want to pull it one day, find out whats in it and give it a coat of paintas its pretty scruffy.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#17 |
Old Skool Club
![]() Join Date: Jun 2001
Original '69 350 with correct identification (supposedly rebuilt at some point), with at least 200K miles on it. RV cam, Hooker headers, Edelbrock 2101 intake with Edelbrock Q-Jet and an Accel HEI replacement distributor. Oh, it has "some" oil leakage and "a little" blow-by. But, it still ran great until it was pulled out in September!
What would I like to have in its place? I think a Tri-Power 421 Pontiac would be nice.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#18 |
![]() Join Date: May 2008
'68 327 + 0.030 over with Keith Black 10:1 hyperneutic pistons, Comp Cam XE280 cam + valve train sitting on factory Vortec heads, Edlebrock Performer intake with a self tuned Q Jet. Flotech headers and Flowmasters. Tremec TKO 600 5 speed with 3.42 posi out back.
The what I would change is what I just completed, cam change from XE252 to XE280 and tranny swap from T-5 to TKO. LOVE IT! Daily driver Step on the loud pedal and listen to the eagles scream . . .
Mine is chopped, has a clutch, and a big block. |
#19 |
My Carbon Footprint
You little 383/406 guys! lol
BBC all the way! ![]() |
#20 |
[QUOTE=prostreetC-10;3354706]You little 383/406 guys! lol
BBC all the way! ![]() ![]() ![]() aaahhhh ok!!!
#21 |
Registered Mail
496 - 4 bolt main, forged everything, roller everything, msd everything, balanced everything, 850 holley dp, massive lift roller cam (over 600 adv.), performer rpm heads, air gap intake, large tube headers, hooked up to a TKO 600 tranny.
the one thing I may change is add at least a 200 shot of nitrous to get this baby over 800hp...
'67 chev 496, lwb to swb, bagged - pro street project |
#22 | |
My Carbon Footprint
#23 |
396 BBC from Speed-O-Motive in my 67 Camaro with 750 Holley 3310, mild cam, 10.25.1 compression, Edelbrock Performer, stock heads, Dynomax headers, Pertronix, runs great. 350 in my 68 C10 with stock cam, Weiand dual plane, 600 Holley 4160, log manifolds, new Procomp HEI, runs smooth and cool.
#24 |
250 inline
HEI Offy Intake 500 cfm Edelbrock Three on the Tree Thinking of going to a little smaller carb.
Working on my first 1,000 post. I'm sure I'll get there before this project is over ![]() |
#25 |
stock 350 3310 holley airgap rpm
want to switch to ls1 or blown 427 but I need to finish body work first |
