Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-29-2010, 10:59 AM   #1
blazer2007
noisy compressor
I was wanting to build a insulated box around my air compressor as is loud.Any suggestions,I don,t want it to overheat or starve it for air.Is just a little 4 hp.type and I can,t move it as is the only plug in that won,t set off the breakers
blazer2007 is offline   Reply With Quote
Old 10-29-2010, 11:26 AM   #2
cdowns
cdowns's Avatar
Re: noisy compressor
is this an oilless compressor? if so not much can b done as they run very noisy and very hot any insulation will shorten thier already shortoverall lifespan
Old 10-29-2010, 11:44 AM   #3
specialtyretail
So,, what else you got???
specialtyretail's Avatar
cdowns is correct. Do not build a box for it, it will overheat. We have one of those and it will run you out of the shop. Sitting them on a rubber mat helps,,,, some, but not too much. A belt driven compressor is the way to go..
specialtyretail is offline   Reply With Quote
Old 10-29-2010, 04:37 PM   #4
Psycho71
Psycho71's Avatar
Agreed, while my oil-less did last a long time, I wish it would have died sooner. It absolutely hate listening to those things. many times i would use a breaker bar and a lot of cussing before I'd turn on the oil less and break out the impact.
Build a lean too outside for if you can.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
