C/10 junkie
Ok I did a disc brake upgrade to my 68 swb. I already had a power booster and now it feels like it isn't working. I used a 1975 Corvette style master cylinder and the truck stops ok but the pedal is hard. Any ideas?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
![]() Join Date: Dec 2012
Re: New master and now no power brakes
How do you Upgrade to newer style Brakes ?
1971 GMC Sierra 1959 GMC 100 |
C/10 junkie
Went from drum to disc...
Oh simple as that then
Just the front disks, upgraded? I'm guessing that you got a CPP master and prop valve combo for disk/drum or disk/disk, which ever you have? Bore size on the master, did you change the pushrod, bleed the brake system correctly?
Posted via Mobile Device |
C/10 junkie
I used a rebuilt 75 Corvette master with a 1" bore. Stock rebuilt booster that is workiń properly and I believe I bleed the system good. Nice firm pedal. Front disc upgrade only with new CPP disc/drum prop valve
Also since you had the booster already, did you look to make sure it didnt have fluid in it? I had to replace mine due to this. And another is poor vacuum pressure. Where are you porting the vacuum for the booster from?
#8 | |
C/10 junkie
C/10 junkie
My concern was maybe I should of used the 1 1/8 inch bore master but I figured the smaller bore would cause higher pressure.
C/10 junkie
After reading this I'm thinking I may need to switch to the larger 1 1/8 bore
http://67-72chevytrucks.com/vboard/s...d.php?t=561809
#11 | |
#12 | ||
C/10 junkie
Driving it to work this morning made me realize that I will get used to the firmer pedal and that there is like a half pedal that feels like power and then it hits a point where it feels like manual brakes. I was thinking that with the larger bore that there would be less stroke and maybe that would keep it in the power brake feel realm?
Did you properly bench bleed the master ? Not sure if that is a brand new (looks brand new from the pic). All the brand new master cylinder I get has a note saying to you have to bench bleed it or at least comes with 2 lines where you can bleed it in the car before installation of the hardlines.
I have done drum to disc on the front of my C20. I have a prop valve that looks like the one on your truck. I am told that the lines have to be reversed to work.... Could this be the issue?
Have you called CPP? I am sure they have run into a question like this before. I have not hooked it up YET. That comes this weekend. I went back to the distribution valve for now and it feels spongy.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#15 | |
C/10 junkie
#16 |
67-72 parts collector,…
![]() Join Date: Nov 2002
I would try a stock 71-72 M/C.
They have the 1-1/8" bore. http://www.oreillyauto.com/site/c/de...01292&pt=01292
#17 |
C/10 junkie
Thanks Keith no actually got one of those yesterday
![]() ![]() Posted via Mobile Device
#18 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Shawn, after reading the link you posted, I think the larger bore is what you need. I think you're heading down the right path.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#19 |
C/10 junkie
Well the silver lining in all of this is I will be able to pre paint the new master
#20 | |
No painting that will eventually rust anyway. I painted my '69 M/C with cast look caliper paint,... but now it's starting to look like crap. (with almost no miles on the truck)
#21 | |
C/10 junkie
#22 |
![]() Join Date: Oct 2009
I believe the discussion above regarding which line from the mc goes to which port on the prop valve is valid - but only for a 3/4 ton truck (pic of my 3/4 attached). Note rear mc res attaches to the front port of the prop valve and vice versa. You can see the 1/4 (rear) lines and figure out which ports/reservoirs feed the rear brakes and which other ones feed the fronts.
My inline tube purchase matched the old lines between mc and prop valve. BUT, your truck is a 1/2 ton - so my point is dispel the confusion between 1/2 and 3/4 ton. Your mc to prop valve lines are right for a 1/2 ton and the pic below is right for a 3/4 ton. Last edited by jocko; 04-02-2013 at 02:51 PM. |
#23 |
Junior Member
Yep, mine rusted before it was done at the shop. I have a aluminum one for my 72.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#24 | |
C/10 junkie
#25 |
Junior Member
That is what I used and it still rusted.
