Old 07-15-2014, 11:57 PM   #1
jimcaf
jimcaf's Avatar
LS1 motor mount position help
I bought the basic conversion mounts,now that im looking at them it appears they can go in 3 different positions moving the motor forward or back.The mount in the picture im not sure if looks like it can also go on either side, Im temped to start with the one in the photo on the passenger side with the corner where I have the arrow pointing forward in the forward holes.Anyone thats been there and done it if you could shed some light Thanks Much jim
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION
Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed
The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10
jimcaf is offline   Reply With Quote
Old 07-16-2014, 09:59 AM   #2
67 chevelle
67 chevelle's Avatar
Re: LS1 motor mount position help
They mount in the forward holes , the upper forward hole is where the beveled hole mounts
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-16-2014, 10:12 AM   #3
trkfrk
trkfrk's Avatar
Hope this helps.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 07-16-2014, 10:31 AM   #4
jimcaf
jimcaf's Avatar
Mark, I just found an old post photo enclosed ,with your mounts if Im reading this right your motor then is 3 inches forward of a stock SBC.How has that worked out for you in the front as far as spacing between the motor and radiator? I like the idea of it being forward like yours for the convenience of access to the back of the motor
Old 07-16-2014, 10:44 AM   #5
trkfrk
trkfrk's Avatar
Originally, I set the motor in the stock location (original holes). Once I installed the cab I didn't like the large gap between the engine and cab. So I welded up the stock holes and moved the engine back approximately 3".
Mark
Old 07-16-2014, 10:56 AM   #6
jimcaf
jimcaf's Avatar
Mark ,if your plates match diagram 3 on the bottom sounds like yours is in the stock location now after moving it back 3?
BTW your truck looks outstanding,nice work!! jim
