04-13-2015, 07:33 PM | #1 |
Correct steering column brackets?
I am replacing the 80's style steering column in my truck back to the original column, due to the current column not being installed with the highest quality. However before i buy the new column, I need all the original brackets for my 69 C-10. I see them on Ebay and wanted to make sure these are the correct brackets for what i need before i pull the trigger and buy em. Thank you in advance!
John San Diego, CA 1969 C-10 “ A person who never made a mistake, never tried anything new.” Albert Einstein |
04-13-2015, 07:50 PM | #2 |
Old member
Re: Correct steering column brackets?
Yep those all look like the right ones to me.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-13-2015, 07:58 PM | #3 |
Ok, thanks!
07-04-2017, 02:30 PM | #4 |
I have a 71 blazer I got apart. Does anyone no were I can get the mounting hardware for steering column under dash?
Posted via Mobile Device |
03-06-2019, 06:53 PM | #5 | |
The Older Generation
Try the truck or Blazer classifieds. You can't post a "Want To Buy" unless you are a "Premium" member but if you see something for sale you can buy it. A lot of guys parting trucks & Blazers..... LockDoc
03-06-2019, 01:19 PM | #6 |
jjlett69 exactly what I was looking for. Can you or anyone else tell me what sized mounting hardware (nuts / bolts) get used in those brackets and where?
Thanks Mike |
03-06-2019, 06:56 PM | #7 | |
Kind of depends on what year. The '67 & '68's are a little different because of the emergency brake location.. Most of the bolts are 5/16 x 3/4 or 1 inch. LockDoc
