05-31-2019, 04:11 PM | #1 |
How to flip seat back forward
Just picked up a new to me, 71 Cheyenne Super. Wondering how the seat back (bench seat) blips forward so i can access behind the seat area? Thanks in advance!
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 Last edited by domano 68; 05-31-2019 at 04:17 PM. |
05-31-2019, 04:44 PM | #2 |
Re: How to flip seat back forward
They don't flip forward.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
05-31-2019, 05:33 PM | #3 |
jbarron is correct.. The seat doesn't "flip" forward.. However, if you need to access the fuel gauge sending unit, you can remove the 4 (2 on each side) seat mounting bolts in the rear and loosen the front 4 bolts.. Tip the seat forward and place a block of wood under each rear "foot".. This will allow you to gain access to the sending unit without fully removing the seat... Replace and tighten the bolts when you are finished.. Don't drive the truck with loose or removed bolts..
05-31-2019, 05:49 PM | #4 |
I'm no expert, but my bench seat leans forward. I think there's some extensive discussion about this on the forum. I vaguely remember something about it changing based on year?
Either way, pulling the seat isn't very hard if you need to access that area.
1968 GMC C2500 Long Bed Fleetside |
05-31-2019, 10:27 PM | #5 |
Moderator
67-68 fold forward, 69-72 do not
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-31-2019, 10:58 PM | #6 |
06-01-2019, 11:16 PM | #7 |
Good to know, thanks!
Interesting. Seems like a step backwards though. I wonder if they thought about how do people access the area behind the seat.
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
06-02-2019, 12:17 AM | #8 |
Unsure if it’s correct for my truck as it’s how I got it 15 years ago. But my 70 appears to have angle adjusters that just had the lower lock nuts removed and now it flipped forward
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
06-02-2019, 07:34 AM | #9 |
That's a 67- early 68 flip seat Later 68 -72 bolted solid with the upholstery covering the arms .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-02-2019, 11:08 AM | #10 |
Actually GM and most other companies made the change over in 67. My 66 chevelle has flip seats no latch buttons which is correct . I have 67 gto seats that have the button releases. It also has the mounts for the three point seat belts. Even though they weren't installed.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-02-2019 at 01:30 PM. |
06-02-2019, 01:00 PM | #11 |
While we're on the subject then, what would make good fold-forward bench seat candidates for swapping into our rigs?
I know that I wish there were a couple more inches between me and the steering wheel; I'm always trying to push myself back. So a really thick, plush seat would make that worse for me. (and I don't have much of a beer belly either!) |
06-02-2019, 07:00 PM | #12 | |
06-02-2019, 02:12 PM | #13 | |
06-02-2019, 01:53 PM | #14 |
Moderator
If you need more room between you and the steering wheel, collapse your intermediate shaft and bring the column closer to the dash. Changing a seat will not gain you any room. Once the seatback hits the cab, it isn’t moving back any further unless you angle it forward, making it uncomfortable and unable to lean back.
06-02-2019, 03:48 PM | #15 | |
I've got my brake booster out right now anyway for some major re-wiring at the firewall........................"as long as I'm here"!! Anyone got pics of moving the neutral safety switch back? It looks pretty close to the firewall already! |
10-22-2019, 01:35 PM | #16 |
Can a non folding seat be made into a folding seat?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
