06-18-2020, 09:39 PM | #1 |
Tahoe Floor Access Plate?
Really curious as to why GM never put a removable access plate above the fuel pump on Tahoes, Yukons and Suburbans? A simple 12'' x 12'' plate configured to the floor above the fuel pump would make a fuel pump replacement SO MUCH EASIER! Had the pump replaced on our '99 Tahoe and required dropping the tank. That SUCKS big time. With just buying this '05 Tahoe the thought crosses my mind to do such if ever have to replace the pump rather than dropping the tank.
Thoughts on this would be much appreciated. Anyone ever done such a modification to their Tahoe or Burb?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
06-19-2020, 07:20 AM | #2 |
Re: Tahoe Floor Access Plate?
That would make it smart. Mywife's old Kia was that way, although we never needed it in 180K.
06-19-2020, 01:07 PM | #3 |
No access panel on burbs or Tahoes that I'm aware of. My 2002 Yukon XL had dual tanks and no access panels from above, had to drop both tanks to replace the pumps. The main tanks are under the passenger area floor.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-19-2020, 06:17 PM | #4 |
Understand about the lack of floor plate access panels. Just think it would have not been that much for GM to install them going down the assembly line. A bit of consideration and forethought would have been nice on their part. Have owned three Suburbans and two Tahoes and always thought that lack of an access plate was poor thinking on GM's part.
06-26-2020, 01:26 PM | #5 |
I installed a fuel pump in my 07 classic and and just cut a hole in the floor. Now I'm looking for a pach panel. They don't make them. Make it much easier the next time to.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
06-26-2020, 02:03 PM | #6 |
had to drop the tank in my 2000 tahoe to change the tank presure sensor honestly wasnt that bad but then again i ran fuel down to almost empty
07-03-2020, 01:28 PM | #7 |
Old Heap Driver
I cut one into the floor of the 2dr 97 Tahoe I owned. I used rivets to add flanges around the edges and screwed the panel to the flanges. A little HVAC duct sealer tape went over the edges. Careful measurements made the job look almost factory, sorry, no pictures.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
07-03-2020, 05:20 PM | #8 |
Sounds interesting for the way you did that. What did you use to do the cutting of the floor panel? Interested in that to get a nice straight even cut. How much room between the floor panel and the top of the tank did you have for cutting?
07-03-2020, 07:29 PM | #9 |
Old Heap Driver
Drilled a hole in each corner, stuffed a welding blanket over top the tank, yes, total PIA. Used a saber saw after cutting off a little of the blade. If I remember correctly there was a couple inches or more between the tank and the floor. Again if I remember correctly the hole was roughly 10" square.
07-04-2020, 10:36 AM | #10 | |
