04-09-2020, 09:15 AM | #1 |
What have you learned new about these truck recently.
Until recently I have never heard of a Sierra Custom Package for our trucks, but it exists.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-09-2020, 10:56 AM | #2 |
Re: What have you learned new about these truck recently.
I learned that 67 to 70 high beam Indicator is different from 71 72. It a rectangle not circular like the 71 72. I also learned you to remove the steering column. Did it yesterday. Super easy once you get it separated from the intermediate shaft.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
04-09-2020, 11:04 AM | #3 |
Funny thing, Ive customized engines, overhauled transmissions, rebuilt differentials etc., but didn't know the bench seat in my truck would actually fold forward if I lifted the vinyl and removed one of the two bolts on each side. I have spent much time scouring salvage yard for a useable bench seat that folds forward. Wow! I used to remove the seat if I wanted access to the fuel tank area, never checked to see the attachment beyond the bolts through the floor! That has become an important discovery for me. Guess I should have asked.
04-09-2020, 11:44 AM | #4 |
That 67's have a one year only ashtray, of all things. Probably common knowledge for most of you, but perplexing to me when I tried to swap one from a 67 to a 68.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
04-09-2020, 12:07 PM | #5 | |
04-09-2020, 12:08 PM | #6 |
Something every day just by reading this board. An amazing wealth or knowledge and experience.
Latest is that the oil fill tube is pressed in. If PCV valve is clogged it was create pressure. To remove rear drums , you have to pull axles Etc, etc, etc. I know, basic stuff but all new to me
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
04-09-2020, 12:09 PM | #7 |
I just recently did a search and learned that the front marker lights on a 67 are supposed to go out when the headlights come on. Thought I still had an electrical issue until I did a quick search. Also found out how you can make them stay on but I'm not sure which way I lean right now. Leave them off or have them on with the headlights.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-09-2020, 12:28 PM | #8 |
Everything since I am new here.
04-09-2020, 12:32 PM | #9 |
Just here to tinker
I just learned that the a/c compressor kicks on on my '67 whenever the blower motor is turned on...regardless whether it is on heat or a/c. I looked underneath to see if something was mis-wired, but everything looks factory. Maybe it's right?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-09-2020, 01:50 PM | #10 |
Yeah, I can't believe I never cheched that. Always just looked for the standard release latch and there wasn't one so thought I was stuck. When I finally surrendered the search for a foldable seat, I was determined to make the necessary hardware and started pulling the vinyl. Lo and behold, two bolts on each side. I reasoned that one could, just could be a pivot bolt so I removed the other and, wadda you know, a folding seat. I was both elated and scornful of myself for not checking earlier.
04-09-2020, 02:21 PM | #11 |
I was on quite a run but nothing lately. Last thing I learned was tailgate latch rods attach using push-through spring clips.....Nothing to write home about.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-09-2020, 02:30 PM | #12 |
I've learned that you better learn as much about your truck as possible and fast and be willing to do your own repairs. It is getting real hard to find a mechanic that can fix anything without a code reader in their hand. Sites like this are next to God when you have a problem. Keep up the good work eh. Have a good one.
PS. I've been to many AC shops to fix my AC and same answer, we can't find any thing wrong, everything is working. I found an "old" guy and he solved it right away. Everything was working and so was the heat valve when calling for AC. The crazy valve was stuck open so was heating my cool air. I'm freezing now and still on R12, no leaks, no change. Last edited by Jim Boy; 04-09-2020 at 04:55 PM. Reason: Making a point in question. |
04-09-2020, 02:38 PM | #13 |
At the body shop.
The knowledge on this board is amazing.
" That didnt make it any newer " " Dont antique the equipment " |
04-09-2020, 04:26 PM | #14 |
I recently learned that the aftermarket upgrade A/C POA valve sold for these trucks and a lot of other GM vehicles, is actually a P.O.S. valve....junk! Don't waste your money, get a rebuildable original and keep your sanity.
04-09-2020, 05:05 PM | #15 | |
I forgot I recently learned 71-72ish tailgate latch bolts are stamped RSC. I was missing one of four for my project, go figure my 72 had four
04-09-2020, 08:24 PM | #16 |
A little over a year ago (does that count as recent?), I learned that all '72 3/4 ton trucks came with power brakes, and therefore, the power brakes option is not listed on the SPID for 3/4 ton trucks in '72.
Post #9 here: http://67-72chevytrucks.com/vboard/s...d.php?t=776630 |
04-09-2020, 08:59 PM | #17 | |
Old member
Follow the cable to the box and you'll find the switch on the back side.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-10-2020, 02:03 AM | #18 |
70+ ( Old Skool Club )
Nothing concrete yet but a member posted that his Spid shows front and rear sway bars. I know our trucks came with a front sway bar but have never heard of or seen a factory rear sway bar on our trucks. No pic of the Spid but the member says he will take one and post it and if a rear sway bar was available on our trucks that will be what I have recently learned about our trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-10-2020, 10:03 AM | #19 | |
My original POA valve was a Delco brand which can be cleaned and recalibrated (if still good) but not rebuilt, the Fridgidare brand can be opened up and rebuilt. Original Air Products has a service for these but it is quite pricey. I found a good used Frigidare brand on eBay that had been cleaned, tested and calibrated for R134 for a reasonable price, I figured if it ever goes bad I have a rebuildable core....works like a charm as is. |
04-10-2020, 12:32 PM | #20 | |
04-10-2020, 04:23 PM | #21 |
I have been slowly fixing my GMC. There are alot of parts that are interchangeable between The chevy's and GMC but not everything. And every so often I find something that won't inter mix. Like I have been changing my lights and turn signals over to LED's. They do not make a LED for my front turn signals. They also don't repop the housing for them, at least I haven't found any.
Brian |
04-10-2020, 04:33 PM | #22 | |
04-10-2020, 06:38 PM | #23 |
That u could order your blazer yellow and it showed up at the dealer orange
04-10-2020, 07:01 PM | #24 |
04-10-2020, 10:03 PM | #25 |
Hey, you gotta elaborate on that one... Are you talking about the orange Blazer that looks 100% original paint and has light yellow on the SPID? (it also had avocado plaid trim I believe) Or at least that's what it was ordered with, dunno if it showed up at the dealer that way or if the factory just built the original owner a totally different blazer than he asked for. Anyway, if none of this rings a bell... pls disregard
